Thread: DTC code 8194; what does it mean?
  1. Re: DTC code 8194; what does it mean?
    2022 Post(s)
    Yes but a hex code of 2002 does not come up either, for example VAG code 17965 would be 462D. I imagine 8194 is a code specific to your code reader and I don’t know what it is, sorry.
  2. Re: DTC code 8194; what does it mean?
    Oct 2009
    Newcastle upon Tyne, UK
    The 8194 code is to do with a blocked DPF as confirmed by the dealer this morning
    The code is also mentioned by patrickhorton in the Cleaning a blocked DPF thread.
    I found it by searching for 008194 rather than 8194.
    2016 A6 Avant BiTDi Black Edition
  3. Re: DTC code 8194; what does it mean?
    2022 Post(s)
    That is a good code, I tried it as 08194 but I never thought to try 008194.
  4. Re: DTC code 8194; what does it mean?
    Oct 2009
    Other codes that also showed up were 001137 and 009299.
    You wouldn't happen to know their meaning would you?
  5. Re: DTC code 8194; what does it mean?
    Dec 2007
    you should look on ross tech wiki
    but those codes relate to the dpf
  6. Re: DTC code 8194; what does it mean?
    Oct 2009
    Spot on!
    Thanks very much.
  1. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  2. Question Non of the electricals working on the left side of my 2005 mk5 gti
    By Moeg5 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-04-2010, 07:59 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
