Thread: DTC code 8194; what does it mean?
Results 1 to 9 of 9
  1. Question DTC code 8194; what does it mean?
    Oct 2009
    Newcastle upon Tyne, UK
    The engine management light came on yesterday morning after I started my car A4 Avant 2.0 TDI 170 quatrro S-line Special Edition.
    I plugged in my Celtic Tuning eMotion unit to check if any DTC fault codes were present. It showed up a single fault code of 8194.
    The ECU has been remapped (FastRoad 207bhp) using the aforemention Celtic Tuning unit.
    Does anyone out there know what DTC 8194 means?
    2016 A6 Avant BiTDi Black Edition
  2. Re: DTC code 8194; what does it mean?
    134 Post(s)
    2022 Post(s)
    It is not a VAG, HEX or a P code so it is meaningless to me, it must be a machine specific code and would need converting into hex, VAG or P
  3. Re: DTC code 8194; what does it mean?
    Oct 2009
    Thanks for the response.
    Do you mean HEX as in hexadecimal?
    If you do then 8194 is 2002 in hex, if not then please pardon my ignorance!
  4. Re: DTC code 8194; what does it mean?
    134 Post(s)
    2022 Post(s)
    Yes but a hex code of 2002 does not come up either, for example VAG code 17965 would be 462D. I imagine 8194 is a code specific to your code reader and I don’t know what it is, sorry.
  5. Re: DTC code 8194; what does it mean?
    Oct 2009
    The 8194 code is to do with a blocked DPF as confirmed by the dealer this morning
    The code is also mentioned by patrickhorton in the Cleaning a blocked DPF thread.
    I found it by searching for 008194 rather than 8194.
  6. Re: DTC code 8194; what does it mean?
    134 Post(s)
    2022 Post(s)
    That is a good code, I tried it as 08194 but I never thought to try 008194.
  7. Re: DTC code 8194; what does it mean?
    Oct 2009
    Other codes that also showed up were 001137 and 009299.
    You wouldn't happen to know their meaning would you?
  8. Re: DTC code 8194; what does it mean?
    Dec 2007
    you should look on ross tech wiki
    but those codes relate to the dpf
  9. Re: DTC code 8194; what does it mean?
    Oct 2009
    Spot on!
    Thanks very much.
  1. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  2. Question Non of the electricals working on the left side of my 2005 mk5 gti
    By Moeg5 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-04-2010, 07:59 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  5. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
