Thread: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
  1. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #11
    Jul 2010
    Kings Lynn
    Hi all,
    If anybody can get in touch with a8 tech can they please point him this way for his opinion. The car goes back this evening and diagnostics start in the morning. Im just dreading them trying to say there is nothing wrong and me not having the knowledge to ask them what they need to check!
    Many thanks.
    Chris Mason
    Audi A4 Avant B7, S-Line, 2.0 TDi 205bhp (remapped from 170), Bose, iPod, Parrot Bluetooth, DIS, Parking Sensors, Cruise Control, De-Badged, Tinted Windows.
  2. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #12
    if you're certain (and further to advice given above) there's something amiss and assuming the car warehouse say there's no fault, get the car to a main dealer. Get them to do a full diagnostic assessment - assuming faults are found, take the vehicle, the report and the bill for it to the car warehouse and insist they remedy the fault.
    That said, it wouldn't be in the car warehouse's interest to fob you off.
  3. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #13
    May 2007
    knee deep in clunge
    14 Post(s)
    If possible provide the engine ecu part number and software version.
    I can check what sw update you have as some move the torque to prevent clutch slip.
    mpg is fine and 40 to 44 mpg is common for b7 170 bhp (remember they are heavier than a mark 5 golf).
    The turbo range is low down and top end loses its grunt, If fuel quantity and boost is ok I would recommend a remap to move the torque curve to your requirements.
    As you are used to the lighter golf which also has differing software I advise you drive a similar 170 a4 and compare.
    I can confirm the a3 is more responsive then the b7 a4 so it stands to reason you may be expecting similar performance and have overlooked the weight and ecu settings the b7 170 requires to meet emission regs and optimum mpg for its weight and body style plus gear ratio.
    vag diagnostics, retrofits and general repairs
  4. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #14
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    I'd like to add to Crasher and A8's remarks with ,check the cat if you are getting gaseous smells
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  5. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #15
    Jul 2010
    Kings Lynn
    Quote Originally Posted by a8 tech View Post
    Thanks very much for your reply a8 tech. The car is in the garage today so i will post what they come back with. Where would i find the ecu part number and software version?
    Thanks again.
    Chris Mason
  6. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #16
    Jul 2010
    Kings Lynn
    Thanks also fourringsrus
    UPDATE: Just got off the phone with the garage. They have put a new egr valve on and are now going to conduct further tests. They have offered no reason as to why they have done this. What could cause them to replace the valve? Do they fail or get blocked? I dont even know what they do or where they are lol.
    Cheers.
    Chris Mason
  7. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #17
    May 2007
    knee deep in clunge
    14 Post(s)
    they do fail but often there are fault codes or complete lack of power.I suspect the garage has its guessing hat on.
    ecu p/n and sw version can be found by vag com or similar
    go to address 01 and via vag com and the information will be retrievable
    2 0 0
  8. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #18
    Oct 2009
    wigan england
    One answer.. get em remapped! The 170s were recalled under warranty to down rate the power, to save clutch and p.d.f. life. I bought one 6 months since and thought it was crap. Had it checked over and nobody could find a thing. Checked the service invoices which came with the car and found one for a software update. I googled the software part number and people reported after having the update done a lack of power.
    Spend a few hundred quid for a good quality remap and your car will pull like a train.
  9. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #19
    May 2007
    knee deep in clunge
    14 Post(s)
    CORRECT, the sw update moved the torque to prevent the high number of clutch failure which occurred but also the update could be reversed.Remap is the solution but ensure its trusted tuner so you do not suffer premature dpf failure or even ask for dpf off if they can as some do and some don't.
  10. Re: 2006 A4 Avant S-Line Tdi 170 Performance Issues - Please Help!
    #20
    Jul 2010
    Kings Lynn
    Thanks for the advice on remaps. It is somthing I want to do. Any suggestions for a trusted tuning company in my area? I'm in Norfolk but am willing to travel. Or, will any of the well advertised online companies be ok?
    Chris Mason
  1. 2007 A4 2.0 TDi S Line Avant
    By a4 s line in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2008, 08:57 PM
  2. Audi A4 range plots a new course
    Last Post: 12-05-2007, 08:34 PM
  3. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
  4. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
  5. New Sporting Audi A6 S Line models arrive in britain
    Last Post: 15-07-2004, 09:40 PM
