Thread: Throttle body alignnment on a Polo
  1. Throttle body alignnment on a Polo
    Sep 2007
    Essex boy in Suffolk
    Tried to alligh the throttle body on a 98 Polo 1.4 8v for a freind whos tick over is high after he removed and cleaned his TB. Followed the procedure on the ross tech site and got this
    then when you switch to basic settings i get this
    can anyone tell why?
    Is it possable to even do this on this model?
    Graham
    Still pretending to know stuff.
    Golf 6 .:R
    Corrado 20vT - BBS RCs, Leather, Bremo's, TFSI and DSG
  2. Re: Throttle body alignnment on a Polo
    May 2009
    Brigg UK
    Hi, I cleaned the throttle body on my girlfriends 98 polo 1.0 a few years back and had the same prob with the hi tickover, turned out to be the coolant temp sensor at fault, why the hi tickover prob started when I cleaned the body I never found out, when I replaced the sensor the problem was instantly 95 % sorted then over a couple of days everything returned to normal.
  3. Re: Throttle body alignnment on a Polo
    Sep 2007
    Thanks Mark, will try it.
    Graham
    Golf 6 .:R
  4. Re: Throttle body alignnment on a Polo
    132 Post(s)
    1979 Post(s)
    The clue is in your measuring blocks 098 screen, zone 4 says “part throttle”. In Measuring Blocks 001, there is an eight digit value displayed. With the ignition on and the engine not running, what is the value displayed there?
  1. A4 B5 throttle body reset problem with VAG
    By adrianwillis in forum VCDS - General Questions
    Last Post: 09-09-2011, 12:12 PM
  2. Polo mk4 1.4 Throttle alignment
    By dj_harps in forum Polo - Derby - Lupo - Fox
    Last Post: 02-12-2009, 02:44 PM
  3. Question Throttle body issue, 6n1 mk3 polo
    By BrickMan in forum Polo - Derby - Lupo - Fox
    Last Post: 19-09-2009, 06:32 PM
  4. re Fast Idle persists after TBA etc Polo 1.0l
    By patrickLL in forum VCDS - Help Requests
    Last Post: 23-04-2009, 02:10 PM
  5. 1998 B5 - Hunting Idle after Throttle Body Cleaning
    By ectwo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 05:53 AM
