Thread: Urgent help required please!!!
  1. Urgent help required please!!!
    May 2010
    brough england
    Hi all i have just had a local garage fit h&r lowering spring to my 2007 a3 s line tdi they are the 45mm drop springs and it now drives terrible it feels like the back end is swaying around when turning. Can any body help ??? Please please.
  2. Re: Urgent help required please!!!
    May 2010
    knaresborough
    possible geomentry issue with altering the ride height, and removing/refitting the suspension. ask the garage if they checked the geomentry, I mean all camber angles as well as front and rear tracking.
  3. Re: Urgent help required please!!!
    May 2010
    brough england
    thanks mate that's what the garage said that i may need to get 4 wheel alignment carried out . think that will be my next move.
  4. Re: Urgent help required please!!!
    133 Post(s)
    1993 Post(s)
    Lowering it should not affect its alignment that adversely, I have often failed to even measure a change on the rear. Mind you it depends on how they got the springs out and in, I use a special compressor that goes straight in and plucks the spring out without disconnecting anything other than the lower damper bolt but if they dropped the lower arm inner mount then they may have messed up the alignment.
  5. Re: Urgent help required please!!!
    May 2010
    brough england
    cheers guys, had a 4 wheel alignment carried out by audi specialist i found nearby. turns out the chimp who did the original spring change for me dismantled just about everything possible to do with the suspension and the car was a mile out, also he over tightened the rear camber bolts and tore the thread off them.
    as you can imagine i'm over the moon. good job i never paid him.
  6. Re: Urgent help required please!!!
    133 Post(s)
    1993 Post(s)
    What a muppet, it takes 15 minutes per side with a proper spring compressor and no touching camber bolts.
    By avspider in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-03-2010, 09:18 PM
  2. No Air coming out of heater....urgent help required.
    By wali110 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-09-2009, 01:52 PM
  3. Important Urgent - Help Required Asap - Thanks
    By RickT in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-06-2008, 09:15 AM
  4. Urgent Ribbed belt help required
    By A6Glider in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-09-2007, 09:55 PM
  5. Very Urgent Help Required!
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-04-2007, 04:48 PM
