Thread: Steering Judder at low speed normal ??
Results 1 to 9 of 9
  1. Steering Judder at low speed normal ??
    Jul 2009
    Bradford
    Quoted this problem to the dealer when my car was with them a few days ago (under warranty). They said it was normal and nothing can be done about it. ???????. How can it be normal ? Everytime I try to park the car or am in slow moving traffic the steering will rumble/judder significantly as if the car is about to stall!!!! I just dont trust the dealer!! Surely there has got to be a fix. Any help please ?
    P.S. I have already played around with tyre pressures!
    2009 58' Audi A4 2.0 TDi 143 S Line Multitronic Lava Grey MMI 2G Bluetooth Cruise
  2. Re: Steering Judder at low speed normal ??
    Bratty Guest
    Staight away I would check your hydraulic steering fluid level. Then if that is OK take it to another dealership and DEMAND they check it out, as unless you are on full lock (and holding it there!) then it should not labour the engine.
    Dunk
  3. Re: Steering Judder at low speed normal ??
    Jul 2009
    Bradford
    Quote Originally Posted by Bratty View Post
    Dunk
    Thank you dunk. How do I check the steering hydraulic fluid? Where abouts in the engine bay is it? Is it the grey bottle in front of the ESP module just behind the passenger headlight?
    Cheers buddy
    Chuck
  4. Re: Steering Judder at low speed normal ??
    Bratty Guest
    Yep, thats the one, Left-hand side front looks like a black sphere.
    Have a look in the manual (I Know!! Males do Not Have to do that) but on about page 233 its states that at Full Tilt the Steering pump MAY! make noises and make the Motor hunt a bit (because of the extra load that the pump is demanding I presume?).
    If fluid level is OK and you are not at full tilt when parking then if the motor is cutting out I would be looking at a fuel injection set-up or managment problem.
    Dunk
  5. Re: Steering Judder at low speed normal ??
    Aug 2008
    Australia
    yeh the steering on my B8 does similar to what you have described.
    At first service I raised this with my dealer who ahem believes "its normal" but I insisted they document my complaint (they have) in case of any problems down the track. I have gotten used to it.
    However I have since read, in a couple of US Audi/VW forums, several threads on this very issue. Audi *apparently* know of the problem, have *apparently* issued a service bulletin about it which *apparently* requires a replacement hydraulic steering hose.
    A4 B8 2.0TFSI Multi S-Line in white
  6. Re: Steering Judder at low speed normal ??
    Jan 2010
    oxford,oxfordshire
    I'd go to another dealer if these guys won't investigate (all they gotta do is the lift the bonnet). You could always call out the roadside service that they offer. Engineer at Oxford Audi said that there is something with the servotronic steering that alot of people had complained about on the B8 but there was nothing that they could do.
    As mentioned above you should be able to go full lock with your little finger (well almost!) no juddering. I have a new B8 and I have already had to have a new power steering system put in, so I wouldn't give up until you have had someone look, if its uner warranty can't see what their problem is. Takes all of 5 mins to determine whether your power steering is knackered by someone in service.
  7. Re: Steering Judder at low speed normal ??
    Jul 2009
    Bradford
    Quote Originally Posted by gazza1 View Post
    Ok, thanks for all the comments guys. My car has been back at the dealership since Thursday morning. Spoke to the master technician yesterday who asked about problems with the steering. He then told me that he needs to keep the car till the middle of next week since has to 'order some parts'. I dont know what to make of this. They can keep it as long as they like as I have a 2010 courtesy A4 S line (same as mine but with less toys!!) and there is NO PROBLEM with the steering or the mpg on this which convinces me even more about mine that there must be a problem.
    Will keep you updated in case it helps someone else with similar problems.
  8. Re: Steering Judder at low speed normal ??
    Jul 2009
    Bradford
    *** UPDATE ***. Just got my car back from Audi - steering judder sorted !! They replaced a power steering hose with a modified one!! Great!! Hope this helps anyobe else with a similar problem. Now the Mpg is still hurting me. Drove to Birmingham and back (280 miles) at average 47 mpg driving at around 70 mph. Still poor in my opinion should be getting above 50 at least!!
  9. Re: Steering Judder at low speed normal ??
    Oct 2010
    england
    Hi, i have recently prchased a Audi A4 B8 (2008) & i have experienced similar problems as yourslef.. when driving slow & turning the steering judders & also after driving for a while the steering becomes heavy. I have taken the car to the dealer they say this is normal. Also i use to get a very good mpg on my previous car Audi A4 B7 but on this new model the average is really poor.
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  3. Sloppy steering
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 04-06-2008, 02:49 PM
  4. Speed sensitive steering - are UK dealers willing to adjust?
    By orangezorki in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-12-2007, 01:50 AM
  5. 1999 Golf 1.9 TDi Power Steering Fluid Low
    By gazza57 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-04-2007, 12:36 PM
