Thread: fan heater working intermittently
  1. fan heater working intermittently
    Hi folks
    Sometimes my fan heater works when I start up , sometimes it doesn't
    When it doesn't, if I hapen to drive over a 'bump', it will start up.
    Obviously there's a loose connection somewhere, but where would be the best place to start ?
    And whilst on the same part of the car, when dial on 2, there's a subtle rattle, less noticable on 3, not evident on 4
    Is this seperate to the problem above, or can they be connected ?
  2. Re: fan heater working intermittently
    Sep 2009
    South Wales
    What do you mean by fan heater? The heater or the fans inside the car?
  3. Re: fan heater working intermittently
    135 Post(s)
    2043 Post(s)
    The brushes on the motor are worn, it needs a new motor, Is it air con or not?
  4. Re: fan heater working intermittently
    Hi guys
    Apologies for not getting back sooner, shifts crept up on me !
    Not air-con
    It's the fan part of the system, the one controlled by the left hand dial that goes up to 4.
    I know there's probably a loose connection with whatever/however the fans elctric is controlled, it's just a case of where to start first, and without getting to the stage of only my legs showing as I go in search !!
  5. Re: fan heater working intermittently
    Nov 2008
    folkestone.kent
    above.....see crashers post.......start there..............
  1. "How To" remove heater fan from mk5 Golf (no pics)
    By mikegally in forum Volkswagen
    Last Post: 26-05-2012, 10:21 PM
  2. Fan heater stopped working Passatt estate X reg
    By jenny35 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-03-2010, 10:43 PM
  3. Heater fan switch not working
    By jcurrent in forum Beetle 2000-
    Last Post: 05-04-2008, 10:06 PM
  4. Fan heater in mk3 volkswagens
    By Ventoro in forum Chat - Anything with wheels
    Last Post: 21-10-2007, 09:42 PM
  5. 96 passat heater fan not working
    By macerena in forum Passat - Archive Topics
    Last Post: 08-03-2007, 07:49 PM
