Thread: B8 SD card prep
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. B8 SD card prep
    Mar 2008
    What file folder setup do you have to have when using SD cards in a new A4?
    do you need to create playlists or does it pick up the songs from within the folders?
    ta
    Ordered - A5 Coupe
    Gone - 58 Plate A4 B8 S-line 2.0 TDI , Brilliant Red , Audi Parking System Plus , Folding Exterior mirrors , Interior light package , Storage package , Audi hill-hold assist , Bang & Olufsen sound system.
  2. Re: B8 SD card prep
    Mar 2008
    Warwickshire
    Quote Originally Posted by hoju99 View Post
    ta
    Create a folder structure but with a max of 4 top level folders, you can't access any folders beyond the 4th folder.
    BB
  3. Re: B8 SD card prep
    Mar 2008
    Quote Originally Posted by belly buster View Post
    BB
    So if i add 4 "artist" folders then put "album" folders within will that work ok?
    Any playlists req?
    Ordered - A5 Coupe
  4. Re: B8 SD card prep
    Mar 2008
    Warwickshire
    Any playlists req?
    Yes that will work fine. Not sure about playlists I didn't need one.
  5. Re: B8 SD card prep
    Mar 2008
    Carnoustie, Scotland
    BB
    I'm pretty sure that all my top level folders are the artists, therefore I have a lot more than 4 folders and mine works fine???
    Hoju99, if you want your tracks within an album folder to play in the album order then check out my advice on the previous SD cards thread.
    2011 A4 2.0TDi S-Line quattro (phantom black), 19" 7 Arm Double Spoke Alloys, Damper Control, Parking Plus, AMI, B & O Sound, DAB Radio, Bluetooth Prep Low
  6. Re: B8 SD card prep
    Nr. Nottingham
    All you need to remember about the SD cards is they support ID3 tags, so if your songs and albums are tagged correctly, you'll get the correct info on screen and the correct play order.
    For file management it's easiest to go Artist top level, followed by album as already suggested.
    The 4 levels refers to *folder depth*. E.g. the scheme above has 2 levels. If you nest greater than 4 deep it won't see the proper structure.
    Delivered 27/5/08: B8 A4 2.0TDi SE, Lava Grey, Black Sports Seats, B&O, Cruise Control, Bluetooth, oh and Parking System Plus, gratis - courtesy of Audi
  7. Re: B8 SD card prep
    Mar 2008
    My MP3's are stored as follows:
    Artist\Album\01 Track title.mp3
    Artist\Album\02 Track title.mp3
    with the correct info in the ID3 tags,should be ok?
    Ordered - A5 Coupe
  8. Re: B8 SD card prep
    Mar 2008
    Here is the way I prepared my SD card.
    I used iTunes to make my mp3, which I happen to do for my iPod anyway.
    Mount the SD card on pc.
    Copy the folder structure onto the the SD card from the iTunes library
    To make the m3u
    I created the playlists in iTunes.
    I downloaded this software that will export your playlists from itunes to m3u.
    http://www.ericdaugherty.com/dev/itunesexport/
    edit playlist to remove path to itunes library with text editor.
    Copy playlist to SD card.
    SD card and playlists now ready for use.
  9. Re: B8 SD card prep
    Mar 2008
    Quote Originally Posted by digigriffin View Post
    To make the m3u
    life was much easier when you only had to press the record button whilst listening to the top 40 chart show on Radio 1
    Ice Silver A4 S-line 2.0 TDI … 19in 7 Arm Double Spoke Wheels, Bang and Olufsen Sound System, Cruise Control, Parking System Plus, Interior Light Pack, Hill Hold Assist, Mobile Phone Prep- Low, Deletion Of Capacity Designation At Rear
  10. Re: B8 SD card prep
    Mar 2008
    Whilst it may sound long winded to get the mp3's and playlist onto an sd card it really is simple and easy to do once you are setup.
    The use of the SD card for capacity and ease of use in new b8 has probably made the 6CD changer I paid to upgrade to, redundant without every having played a CD.
  1. Question iPod prep and Sat Nav
    By R_D_Metcalfe in forum Golf MK5 - 2004 - 2009
    Last Post: 31-05-2008, 05:10 PM
  2. A4 phone prep problem
    By MrGimlet in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-03-2008, 02:49 PM
  3. Telephone Prep
    By deecee in forum Touareg
    Last Post: 24-02-2008, 04:32 PM
  4. telepphone prep
    By Stonkn in forum Audi A3 - Archive Topics
    Last Post: 19-03-2007, 04:22 PM
  5. Problems with bluetooth prep
    By newsboy in forum Passat - Archive Topics
    Last Post: 08-03-2007, 02:17 PM
