Thread: t4 1.9td wont start after replacing engine
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: t4 1.9td wont start after replacing engine
    #11
    azim Guest
    Ive managed to figure out the wires and have connected it to the engine loom and the solenoid is operating correctly .
    So all that remains now is to fit it all in and hopefully if the pump is a good one ,were in buisness .
    Watch this space will keep you updated ..
  2. Re: t4 1.9td wont start after replacing engine
    #12
    azim Guest
    Installed the repaired diesel pump and timed up the Flywheel head and diesel pump .
    Gave the engine a couple of rotations by hand to make sure there was no problems with the timing ,and nothing was out of place .
    Cranked the engine while bleeding the fuel lines ,managed to get the engine running pretty quickly .
    I am very happy that the diesel pump is working as it should and the engine is running fine bar a slight hi idle .
    As with all work on new engine installs ,i seem to have a small fluid leek ,but its fair to say im one very happy bunny .
    Thanks to all the help given ,thanks to you i have managed to repair what i believed was a duff diesel pump .
    Cheers Guys
  3. Re: t4 1.9td wont start after replacing engine
    #13
    Well done I like a happy ending.
  1. Diesel Particulate Filter on Engine BMK
    By Leoflavio in forum Phaeton
    Last Post: 10-05-2010, 12:33 PM
  2. Lamborghini gallardo lp 570-4 superleggera
    Last Post: 02-03-2010, 08:17 PM
  3. Lamborghini gallardo lp 570-4 superleggera
  4. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
  5. Answers From The Oil Expert Part 2
    Last Post: 22-10-2007, 08:30 AM
