Thread: Is My Temp Sensor Faulty
  1. Is My Temp Sensor Faulty
    My Audi a3 1.9 TDI 130 temperature gauge seems to be playing up when i get in the car without putting the key in the ignition the temp gauge will go To about 70c without the keys in the ignition and if open and close the driver’s side door it will sometimes go back down and when driving the temp gauge seems to sit around 100c
    Audi A3 1.9 TDi 130
  2. Re: Is My Temp Sensor Faulty
    i had the same trouble on my car,turned put to be dash insert (new clocks)
    think it cost about 250 if i can remeber rightly!
  3. Re: Is My Temp Sensor Faulty
    Quote Originally Posted by andrew-spike View Post
    Got a VAG-COM scan done today found two faults
    1 Engine Coolant Temperature Sensor (G62)
    2 Fuel Temp Sensor (G81)
    i am going to replace the sensors and see what happens
    il let you know how i get on
    Audi A3 1.9 TDi 130
  1. Question Is the water temp sender the same as the fan temp sender?
    By 1969ghia in forum Touran - Sharan - Caravelle
    Last Post: 01-06-2010, 06:42 PM
  2. Question Coolant temp in matrix drops when i accelerate
    By irishpassats in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 04:22 PM
  3. running temp of a 1.9tdi
    By solorider in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-05-2008, 11:03 PM
  4. Oil Temp / Water Temp
    By cronic in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-01-2008, 01:40 PM
  5. A4 1.8T 2001 Temp problems
    By alorgat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-01-2008, 06:23 PM
