Thread: Audi A3 2.0 TDI (2005/55) Vagco help
Results 1 to 10 of 13
  1. Audi A3 2.0 TDI (2005/55) Vagco help
    Jul 2010
    London
    Hello folks.....
    First post so bear with me. The ESP light is on constantly on my A3, first appeared about 4-5 weeks ago and I've just had it hooked up to the Vagcom and it returned the output below. Would appreciate if anyone ahs any thoughts on this, I've read several forums on the specific output and at I'm beginning to wonder if this is going to cost a packet to fix! Thanks in afdvance for any help you can provide:
    VCDS Version: Release 805.0
    Data version: 20080529
    Tuesday,06,July,2010,22:02:48:26365
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
    VIN: WAUZZZ8P66A105046 Mileage: 48640km/30223miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC G000AG 7000
    Revision: 12345678 Serial number: AUX7Z0ENFN80BZ
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 S HW: 02E 927 770 AE
    Component: GSG DSG 070 1102
    Revision: 04507000 Serial number: 00000511010193
    Coding: 0000020
    1 Fault Found:
    18255 - Please check DTC Memory of ABS Controller
    P1847 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Reset counter: 1
    Mileage: 48441 km
    Time Indication: 0
    Date: 2010.06.05
    Time: 08:14:38
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
    Component: ESP FRONT MK60 0102
    Revision: 00H13001
    Coding: 0023170
    1 Fault Found:
    01435 - Brake Pressure Sensor 1 (G201)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 P HW: 8P0 820 043 P
    Component: KlimavollautomatH17 0260
    Revision: 038362 Serial number: 8P0820043P
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Revision: 00H36000 Serial number: 00000002284134
    Coding: 01884F07A214100000000000000000000008FE175C0100
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Revision: 91H1135 Serial number: 0037W00157Z4
    Coding: 0071612
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H34 0070
    Coding: 0011142
    Part No: XXXXXXXXXXX
    Component: E0221 H03 0080
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 224NED06007022
    Coding: 0000413
    Shop #: WSC 00060 210 88568
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 3000105A258538
    Coding: 3F0F0F4207000101
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D06 Serial number: AUX7Z0ENFN80BZ
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000560
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000186D288505489AC63300
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659525646043
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 H
    Coding: 0000560
    Address 56: Radio Labels: Redir Fail!
    Part No SW: 8P0 035 195 HW: 8P0 035 195
    Component: symphony II EU H58 0460
    Revision: 23S Serial number: BZ1Z4E6155291
    Coding: 0001001
    Shop #: WSC 130873 003 00000
    Address 76: Park Assist Labels: 8P0-919-283.lbl
    Part No SW: 8P0 919 283 A HW: 8P0 919 283 A
    Component: Parkhilfe 4-Kan H09 0020
    Revision: 00H09000 Serial number: 00067824820531
    Coding: 0001003
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    Tuesday,06,July,2010,22:04:50:26365
  2. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Oct 2009
    Staines, UK
    01435 - Brake Pressure Sensor 1 (G201): Electrical Fault in Circuit
    Possible Causes
    Brake Pedal Switch (F) faulty/jammed
    Brake Pressure Sensor 1 (G201) faulty
    Possible Solutions
    Check/Replace Brake Pedal Switch (F)
    See Measuring Blocks
    Check/Replace Brake Pressure Sensor 1 (G201)
    ABS Hydraulic Unit (N55) may need to replaced
    Perform Brake Pump Bleeding
    Perform Brake Pressure Sensor 1 (G201) Basic Setting
    Replace Brake Electronics Control Module (J104)
    The above is from the Ross-Tech wiki
    I'd start by having a look at the measuring blocks for brake pedal switch and the pressure sensor to see if they are giving sensible values.
    '56 Passat 2.0 TDi 140 SE Estate
    Fully registered VCDS HEX-USB+CAN
  3. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Jul 2010
    London
    Thanks bundao! I'll look at those and if I find a fix reply back to the post.
    Cheers. Paul
  4. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Nov 2008
    folkestone.kent
    your brake pressure sensor is not good news on a mk60 abs unit there is lots of posts on the forum about this type brake pressure sensor. look on the search and be prepared for some not so good reading
  5. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    May 2008
    You can get the unit repaired for £350 ish or replaced for £1k+
  6. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Mar 2010
    notts u.k
    Done a few of these on golf 5s the g 201 is in the abs unit as Has already Been said you will need to fit a new pump or get it repaired last one we bought was 612 plus vat from tps but a company called ecu testing refurb them now either way it won't be a cheap fix I think vw now acknowledge they are rubbish as I've read on the net of goodwill repairs for this out of warranty have a google for g201 sensor golf they are the same units with the same fault
  7. Exclamation Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Dec 2008
    Salisbury Wiltshire
    Hi, i have an A3 tdi which i have been pretty impressed with over the last 3 years HOWEVER... it has had a few glitches to say the least since ive had it the latest is the appearance of the ESP light , the car is 4 years old and 55k and full audi history , im not impressed one bit at the idea of having to shell out £1500 for a new ABS pump that was clearly badly designed as i have read hundreds of complaints today on various web sites , i havent been to Audi Salisbury yet but will be in there intray Monday ,has anyone had this problem solved totally at no cost by either goodwill gesture or by quoting the sale of goods act
  8. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Quote Originally Posted by Big Skinny View Post
    the car is 4 years old and has covered 55k, which part of the SoGA do you intend to quote?
    Personally, I'd have a diagnostic check completed on the vehicle, I'm no expert but I should imagine there's more than one possible cause for the appearance of the ESP light?
    If you intend to gain any goodwill from a dealership, going in with a hostile attitude is something I'd discourage you from.
  9. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    Dec 2008
    Salisbury Wiltshire
    Hi thanks for reply , ive read loads of those threads as i said and 99% point to the abs pump all with various out comes but most have been told to part with £1500 until questioned as for the Soga i intend to if necessary quote that the goods sold to me has a costly repair needing done that is within six years of purchase and that due to the amount of people that have had these problems that the part itself was inherently faulty and not broken due to neglect or abuse in anyway as for the attitude on which i approach them my wife will contact them lol probs best eh ?
  10. Re: Audi A3 2.0 TDI (2005/55) Vagco help
    the trouble with reading threads and basing a diagnosis on these can lead to inacurrate identification of faults.
    As said, I'm not an expert, but the first step in any (especially with modern cars) is to run a diagnostic check - then see how the land lies.
    In regards to your SoGA point, whilst I sympathise, what you're suggesting would require Audi's agreement. I cannot see Audi agreeing with you that the part was flawed in design. It's very difficult to prove techincal flaws, as opposed to natural wear and tear on components.
    Hopefully the more techincal members can offer and input, but personally I would figure out exactly what the problem is before panicking about the £1500 bill.
  1. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  2. Replies: 0
    Last Post: 04-10-2009, 02:16 PM
  3. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  4. 50mpg-plus Audi Diesel Sports Car Cleans Up In Geneva
    Last Post: 27-02-2008, 10:24 PM
  5. Record results for vehicles sales, revenue and profit
    Last Post: 12-05-2007, 08:33 PM
