Thread: Blue Smoke on start up
  1. Blue Smoke on start up
    Jun 2010
    Ireland
    I've noticed when I start the car from cold theres a lot of blue smoke from the exhaust. When I accelerate alot more comes out. After the car is taken for a spin it seems to be no existant from what I can see.
    I've given the car a good cleanout i.e. 3rd gear 70mph 4500rpm for 10mins so its not build up.
    I recently discovered a tuningkit.com unit in the car could this be it giving a rich mixture at low revs.
  2. Re: Blue Smoke on start up
    i looked into that kit peter - seems it alters the fuel pump - why not take it off and see how the car runs , that chip maybe fauly or dead if its been fitted for a long time. cant hurt anything for trying with it off.
  3. Re: Blue Smoke on start up
    Jun 2010
    Ireland
    Cheers, Yeah I was thinking I may take it off and see if theres a noticable decrease in preformance or more importantly blue smoke.
    I'll have to see about getting a dyno test done as you say to see whats actually going on.
  4. Re: Blue Smoke on start up
    Norfolk
    I would check the EGR valve is working correctly. Might be an idea to undo the bootom intercooler pipe and see how much oil pours out.
  5. Re: Blue Smoke on start up
    Jun 2010
    Ireland
    I've disconnected the tuningbox.com and it seems to have fixed the problem. I haven't had much time to test it but started it up from cold this morning and ok.
    There is oil collecting around the bottom of the intercooler. I take it the intercoller is (if your standing at the front of the car looking at the engine) on the right tucked into the bumper. There is a bit of oil collecting here and on the plastic cover but I was told this is normal as the engine wears oil will come out the breather pipe. There isnt a massive amount and its not dripping just residue over time.
    Where is the EGR valve and how can I check it.
  6. Re: Blue Smoke on start up
    DSG4ME Guest
    Engine cover, next to the oil fill cap, looks like a brass top hat, if you pull the pipe off it, you should be able to feel suction at the pipe, if the car has done 50k plus the EGR will be dirty, and is cleanable.
  1. dense blue smoke on acceleration
    By sparkymark in forum Polo - Derby - Lupo - Fox
    Last Post: 12-06-2009, 06:09 PM
  2. Blue Smoke
    By macmillions in forum Golf MK2 - 1984 - 1992
    Last Post: 20-05-2009, 09:16 AM
  3. Blue Oil Smoke - Just serviced. What's Going On?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2009, 08:47 PM
  4. Dreaded Blue Smoke ....
    By Jabba in forum Passat - Archive Topics
    Last Post: 02-03-2007, 06:34 PM
  5. Blue smoke in traffic
    By avhation in forum Archive posts
    Last Post: 21-11-2006, 12:21 PM
