Thread: Electrics on drivers door not working
Results 1 to 10 of 17
  1. Electrics on drivers door not working
    lithium Guest
    Hello all
    I did have this post in the VCDS section but thought i might put it here instead...
    I have genuine VCDS
    Mk5 2006 Golf 1.9 TDI
    I removed the drivers door last week to be resprayed, i got it back this weekend and fitted it.
    The central locking works as do the speakers and the window motor (only way i can open/close window is via the key fob) but nothing else works.
    I cannot open/close any window from the 4 way switch, nor change wing mirror position nor open the fuel latch.
    VCDS scan says everythink is groovy, I have no faults. I have taken the door card off and had a nosie around and everything looks fine.
  2. Re: Electrics on drivers door not working
    lithium Guest
    would i need to reprogramme the CCM??
    Also, i have left the battery off for a few days and then taken her for a drive, no difference unfortunately
    cheers
  3. Re: Electrics on drivers door not working
    lithium Guest
    does anyone know the defualt coding for the drivers door electrics?
  4. Re: Electrics on drivers door not working
    Kinross Scotland
    Here is a copy of the scan from a 2008/2009 Golf 5 four door.
    It is the default settings.
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 1220
    Coding: 0000692
    Shop #: WSC 01357 011 00200
    No fault code found.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  5. Re: Electrics on drivers door not working
    lithium Guest
    Hi Richard
    Thanks alot, ill try that today
  6. Re: Electrics on drivers door not working
    lithium Guest
    didnt do anything different unfortunately,
    thanks though
  7. Re: Electrics on drivers door not working
    Kinross Scotland
    Had a quick look in ElsaWin and the driver door switches all go to the drivers door controll unit via a 32 pin plug.
    Did you disturb this ? could overspray or spray dust be insulating the pins ?
    Worth giving it a wiggle.
    If you want diags send me a PM with an Email addy. Regards
  8. Re: Electrics on drivers door not working
    Mar 2009
    Sydney, Australia
    Quote Originally Posted by lithium View Post
    thanks though
    The most likely reason - something was not plugged in as it was, but you might need to look at harness to the chassis connector for any damage.
    Golf mkV 2.0 TDI DSG - 2005
  9. Re: Electrics on drivers door not working
    lithium Guest
    Hi Richard - Ill PM u my email, thanks mate
    HT - Ill take the door off tonight and have a good look at the electrics, its just weird as everything works via vagcom (output tests) and no faults are shown on a scan.
  10. Re: Electrics on drivers door not working
    lithium Guest
    Quick update for anyone interested;
    I changed the door switch (4 way window one) on the drivers door, no difference.
    I tool the boot off of the door to check the wiring from door to chassis, couldnt see any problems.
    VCDS still not throwing up any error codes unless i physicaly disconnect the switchers that are not working?!
    This is blowing my mind, I really cant think of anything else and i really dont wanna take the car to the dealer either!
    Any more suggestions/ideas?
    Im sure the coding for the door is now correct
  1. Golf Mk 6 towbar and electrics - help!
    By mrmagoo2 in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 28-06-2022, 10:23 AM
  2. Replies: 7
    Last Post: 17-09-2017, 08:01 PM
  3. Sharan Electrics?
    By grandos in forum Touran - Sharan - Caravelle
    Last Post: 18-01-2010, 06:46 PM
  4. Two Click Remote Central Locking (All Soors) Stopped Working
    By JamesVW in forum Golf MK4 - 1999 - 2004
    Last Post: 11-12-2009, 01:35 PM
  5. drivers door electrics
    By vinny1965 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-01-2008, 05:13 PM
