Thread: ABS wiring Loom diagram
  1. Re: ABS wiring Loom diagram
    May 2008
    yep , that makes sense now I have a starting point. My viewer has made the diagram a little fuzzy, but now I know what I am looking at.
    Unfortunately, it has not enabled me to find a problem! All wiring buzzes out and the junction in the front passenger well looks OK. I have even disconnected the wheel sensors at the connectors in the passenger footwell and had that reported on the dash as well as ABS failure! This would mean that the ABS ECU is functioning to a degree I think as the signal from the sensors goes straight into the ABS ECU.
    AAAAAAAARRRRRRRRRRRRRRRRRRRRRRRRRRRR!
  2. Re: ABS wiring Loom diagram
    Feb 2010
    Lancashire UK
    Your code says to me that the dash is not always recieving data from the ABS unit. This could mean that there is a break in that wire, or it could be that there is no expected data coming from the ABS unit, say from the ABS unit loosing it's supply or it's ignition feed that might switch it on. Check you have a good earth (brown wire) to the ABS and there is no difference in the earth to the dash.
    Charlie
  1. Injector wiring loom help info and photos
    By vroooOOOM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-11-2016, 08:19 PM
  2. ABS Warning light etc
    By churchy5 in forum A2
    Last Post: 21-04-2010, 11:32 AM
  3. Please Help B4 ABS wiring diagram
    By arturito64 in forum 80 - 90
    Last Post: 09-04-2010, 06:01 PM
  4. Integral Bluetooth radio for A4
    By Gary M in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2010, 03:45 PM
  5. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
