Thread: Brake and indicator lights stopped working.
  1. Brake and indicator lights stopped working.
    James paul 74 Guest
    Hi all. My Audi a3 1.8 se brake lights suddenly stopped working, including the one in the back window. Also the indicators click and flash once then stop! The hazard lights work ok. Any idea what might be causing this? Thanks.
  2. Re: Brake and indicator lights stopped working.
    Southern County Softy
    20 Post(s)
    Sounds like the flasher unit has gone, its part of the hazard switch.
    Change the switch.
    Bake light switch is on the brake pedal, sounds like that has gone too.
    A4 2.5 tdi QS (mapped)
  3. Re: Brake and indicator lights stopped working.
    James paul 74 Guest
    Thanks kite. Heard something about the switch didn't know it was In the brake pedal. Strange with the indicator as the hazards work but not from the indicator arm. Thanks again.
  4. Re: Brake and indicator lights stopped working.
    James paul 74 Guest
    New hazard switch and switch in brake pedal. That done the trick. Thanks very much!
