Thread: Noisy Cam Chain Tensioner
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Noisy Cam Chain Tensioner
    133 Post(s)
    1989 Post(s)
    In my experience, using a thicker grade oil can make the timing chain adjuster noisier. When I put a brand new VAG exchange engine in my Octavia VRS (it uses a similar adjuster) it was very noisy on start up with 10w/40 mineral oil. After it was run in, I changed to 5w/30 Longlife and it has been quite ever since. I think you should drop the sump lower section (not a bad job on the V6) and check the pick up and have the oil pressure checked, which is a bit of a pain to do as the sender is buried tight into the left hand front of the engine.
    Your engine is designed to run primarily on 95RON fuel and I quote “In exceptional circumstances, fuel with not less than 91 RON can also be used, but this will cause a loss of power.”, so in my opinion your engines ECU map is not designed to take advantage of 98RON so I think it would be a waste of money. If you open your petrol filler flap there will be a sticker and this will say “octane min 95/91 RON” or something like that. If it was designed to use 98, it would say 98/95 and this would apply to 2.8 engines such as the ACK, AHA, ALG, AMX, APR, AQD, ATQ and ATX. Your 2.4 APS and others such as the AGA, AJG, ALFAML, AMM, APZ and ARJ are designed for 95RON operation.
  2. Re: Noisy Cam Chain Tensioner
    Feb 2009
    gliwice, Poland
    Cheers Crasher,
    I think i will drop the sump pan off and have a look and maybe strain the oil and see whats in it. I've done less than 100 miles since i changed it so i'll put it back in for now.
    I know the cars meant to be run on 95. But i didn't realise that 98 would have no added benefits, i assumed the higher temperature of burning would relate to a cleaner burn. Maybe helping the engine? (But you live and learn.) You can't get 91 here in Poland. I think however, what the mechanic was hinting at, is that what the garages are advertising and actually selling differs. I.e. 95 oct will have an octain valve much lower than this. Hence using 98 Oct would therefore be closer to my actual 95 requirements. As a rule i tend to use BP branded garages for just this peace of mind, but i guess any owner could be 'up to no good!' It's typical that the one occasion i fill up from an 'alternative' garage coincides with these issues.
    I'll report back next week.
    Enjoy your weekend.
    Ian
    99 A4 2.4 V6 30V SE
    Never upset a Cracovian Flying Rat.
  3. Re: Noisy Cam Chain Tensioner
    133 Post(s)
    1989 Post(s)
    Well there you have the common misconception of “high octane” fuel, it actually burns slower but it is way too complex an issue to even begin to do it justice here, literally you could write a Degree standard thesis on the subject and still not fully cover it. This Wikipedia article covers the subject a little.
    http://en.wikipedia.org/wiki/Octane_rating
    Its funny you say that you can’t get 91 in Poland as many years ago I used to call 91 Polish petrol. I can’t see the fuel being sold not meeting standards, EU laws and oil company standards simply would not allow that to happen.
  4. Re: Noisy Cam Chain Tensioner
    Feb 2009
    gliwice, Poland
    Haha,
    To quote the mechanic. "There have been cases of Shell branded garages where the octain measured during tests was 82"
    If you look at some articles, they read like horror stories! A few years ago 1 in 8 petrol stations failed the EU standards. The pass rate for the Internal Polish standard is slightly better.
    My favourite comment is,
    "If you are lucky when visiting one of these stations, you'll find water in your petrol; if you're not so lucky you'll be finding petrol in the water"
    Standards are improving but around 3 percent of garages still fail the testing today.
    Since the beginning of the year 90 criminal cases have been brought against garage owners.
    i guess people think the rewards outweigh the risks.
    99 A4 2.4 V6 30V SE
  5. Re: Noisy Cam Chain Tensioner
    133 Post(s)
    1989 Post(s)
    I have never heard of anything in like that in the UK at all but I confess to know little about Poland. However, you quote 82 octane and I think that must refer to the MON (Motor Octane Number) or PON/AKI (Pump Octane Number/Anti Knock Index) number and not the RON (Research Octane Number) as a car designed to use 95RON when filled with 82RON would rattle itself to death. Personally, I only use Shell V Power 99RON in my Octavia VRS and my wife tends to use BP or Texaco 97RON in her Polo GTI.
  1. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  2. Passat 1.8 20V cam chain
    By Petenharvsdad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2009, 09:37 PM
  3. cam belt chain tensioner on seat ibiza
    By Dave Ridley in forum Ibiza - Cordoba
    Last Post: 28-05-2008, 05:41 AM
  4. Cam Chain Tensioner
    By smint1 in forum Archive posts
    Last Post: 03-10-2007, 12:37 PM
  5. Cam belt or cam chain
    By GG_Audell in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-06-2007, 06:15 PM
