Thread: 1992 cabriolet instrument fuse problem
  1. Unhappy 1992 cabriolet instrument fuse problem
    Jun 2010
    Wolverhampton England
    Need a little help here if possible:-s I own a 1992 Audi 80 cab and the fuse keeps blowing for all my instruments?? Where do I start? Please help it's drivin me mad :-(
  2. Re: 1992 cabriolet instrument fuse problem
    Dec 2007
    8 Post(s)
    Quote Originally Posted by Timjp20 View Post
    If its similar to saloon model the first place to check would be the wiring harness in the boot where it flexes each time boot is open / closed.
    The wires fray internally causing short circuit. There may be a multi plug connector in lh panel which could be disconnected to check this out
  3. Thumbs up Re: 1992 cabriolet instrument fuse problem
    Jun 2010
    Il have a look at that first then bud cheers!!
  4. Re: 1992 cabriolet instrument fuse problem
    Gwent
    Further to Michael's suggestion (which is probably the most likely) There could be a problem with the rear number plate lamps or glovebox lamp/switch which are fed off the same fuse.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Cabriolet Seat Problem
    By BoraHighline in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 25-05-2010, 11:21 PM
  2. Please Help 1998 Cabriolet - Electric hood problem told need new ECU...
    By greektony in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 28-04-2010, 10:50 AM
  3. Fuse problem help required
    By spykes in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2010, 10:24 AM
  4. Please Help Blown Fuse
    By smokinjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2009, 01:10 AM
  5. 1992 mk 3 golf alarm/immibiliser problem!!!
    By shadowstalker in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 04:25 PM
