Thread: Cordoba central locking schematic?
  1. Cordoba central locking schematic?
    Jun 2010
    Near Ipswich, Suffolk
    I am trying to locate a fault in my 1999 Cordoba vario's central locking which has just packed up.
    Checked earth and fuses.
    So may be relay? or break in vacum line somewhere, or pump? .
    I live in middle of Suffolk and nearset seat dealer miles away. Also, although they are very helpful on the phone. (The parts guy there also drives an old Verio) I really can't afford anything except do it yerself.
    Anyone goy a central Locking schematic? Guess this is the same as older VW & AUDI?
    Ta!
  2. Re: Cordoba central locking schematic?
    Jun 2010
    Did all Cordobas with central locking come with a 'remote' option? I have beentold they did and remote sensor is in the rear view mirror arm?
  3. Re: Cordoba central locking schematic?
    Aug 2010
    derry
    Quote Originally Posted by soantheseat View Post
    i am trying to locate a fault in my 1999 cordoba vario's central locking which has just packed up.
    So may be relay? Or break in vacum line somewhere, or pump? .
    I live in middle of suffolk and nearset seat dealer miles away. Also, although they are very helpful on the phone. (the parts guy there also drives an old verio) i really can't afford anything except do it yerself.
    Anyone goy a central locking schematic? Guess this is the same as older vw & audi?
    Ta!
    if you can hear a pump running then yes it has central locking , most of the time its the actuator at the fuel cap that bursts causing the problem , because pressure is highest there next to pump. Listen for a hissing noise at fuel cap area, a quicjk fix is just block off hose and hey you have central locking again please let me know if this helps
  4. Re: Cordoba central locking schematic?
    Jun 2010
    Quote Originally Posted by scotini69 View Post
    After quite a seach I have obtained another pump from local scrappy. Fitted it but no joy. Totally dead. I know there is not a leak in any of the pipes as pressure tested system.
    Problem is def power to pump. Odd thing is 15 amp fuse OK, but rear courtesy light which I note is on same fuse also not working. (Bulb fine)
    So I am now down to power supply fault? Earth? Where on eath do I look now?? HELP!!
  1. B5 A4 Central Locking FAQ
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-09-2015, 11:46 AM
  2. Please Help Octavia- Central locking keeps locking.
    By Mawb in forum Octavia
    Last Post: 27-09-2013, 02:53 PM
  3. Remote? Central Locking Unit
    By ImCammers in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2009, 07:08 PM
  4. Problems connecting Remote Central Locking ...2004 Polo E
    By andy4976 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2009, 10:24 AM
