Thread: 1997 1.9TDI power loss & noise?
Results 1 to 10 of 13
  1. Question 1997 1.9TDI power loss & noise?
    Dec 2006
    Oxford
    Couple of days ago my TDI started making a noise a bit like air being sucked in? It comes from the front right hand side and starts at 1,700rpm through to 2,200rpm and is very noitceable with the drivers window down. There's a corresponding loss of power at the same time. Past 2,200rpm the noise pretty much disappears but comes back nearer 3,000rpm along with a dip in power.
    Apart from that, the car's fine, returns an average of 55+mpg pretty much anywhere with 65mpg bimbling along.
    I've checked the air filter, a bit dirty - I was hoping that a clogged air filter would have explained the power loss but wouldn't have explained the noise. I then thought the turbo may be on it's way out but am now thinking that a (vacuum?) pipe of some sort under the bonnet has either worked loose or has split, hence the sucking air noise - any ideas?
    The car's on 116,000 miles with a FSH, I bought it used in early 2007 at 87,000 miles. Checking my records, I can see that the air filter was last changed in February 2008 at 93,00 miles - should it have been changed more frequently?
    All thoughts appreciated.
  2. Re: 1997 1.9TDI power loss & noise?
    front right hand side is where the intercooler pipes are , you need to take the underbelly trays off and have a poke about.
  3. Re: 1997 1.9TDI power loss & noise?
    Dec 2006
    Oxford
    Thanks, will have a look at the weekend.
    Are they prone to splitting or working loose?
  4. Re: 1997 1.9TDI power loss & noise?
    Dec 2006
    Oxford
    Not sure my TDI has an intercooler?
    The air inlet is at the top of the grille, near the bonnet catch, the snorkel goes straight in to the airbox.
  5. Re: 1997 1.9TDI power loss & noise?
    Quote Originally Posted by Possu View Post
    oh ok then , maybe someone else can help.
  6. Re: 1997 1.9TDI power loss & noise?
    Aug 2007
    Your Turbo'd Passat has an intercooler, the air routes from the airbox to the turbo, down to a crosstube, across the front of the car to the intercooler and then to the intake manifold.
    Where the flexible pipe joins the metal crosstube is where the pipe normally spliits or becomes disconnected.
    Remove the undertray and follow the pipe from the turbo and you'll be able to check all the connections.
  7. Re: 1997 1.9TDI power loss & noise?
    Dec 2006
    Oxford
    Quote Originally Posted by creedxup View Post
    Thanks, I thought about this & assumed that the intercooler would be located before the air filter but have since confirmed what you said i.e. the intercooler is located out of sight & that filtered air passes through the intercooler.
  8. Re: 1997 1.9TDI power loss & noise?
    Dec 2006
    Oxford
    Quote Originally Posted by passat 130 tdi View Post
    No, you were right in the first place.
  9. Re: 1997 1.9TDI power loss & noise?
    DSG4ME Guest
    Check all the pipes that lead to the air filter housing, there's one vac pipe that if not on or split stops the turbo working, and the air filter is 40k, but I think that's too long and change them every 20k. hth.
  10. Re: 1997 1.9TDI power loss & noise?
    Norfolk
  1. passat 1.9tdi 74kw Loss Power
    By dorin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 12:08 PM
  2. White smoke loss of power, golf mk4 1.9tdi 98
    By dugpal in forum Archive posts
    Last Post: 21-01-2008, 07:57 PM
  3. Polo 100PD: random power loss!?
    By teccyjim in forum Polo - Derby - Lupo - Fox
    Last Post: 09-01-2008, 02:51 PM
  4. 96 Golf MK3 - loss of power and no start
    By RMANN in forum Golf MK3 - 1993 - 1999
    Last Post: 26-11-2007, 07:37 AM
  5. Loss of Power, Smoke and Whooshing Noise
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-11-2007, 07:49 PM
