Thread: Security problem
Results 1 to 10 of 13
  1. Security problem
    Jun 2007
    My A4 SE has developed an odd problem!
    First of all it opened it's own boot lid while left parked on two separate occasions. The dealer looked at it and found no recorded fault and couldn't find any obvious problem, they reset the central locking and adjusted the boot catch.
    Yesterday after several weeks interval since the previous incident, the car did the same again, while standing outside the house - however this time it also opened both front windows fully!
    This is an obvious problem in that I don't feel confident to leave the car parked in a street or public car park, which I have to do regularly and also if it opens up in heavy rain the interior would get soaked.
    It's back with the dealer, again no faults showing. they are keeping it for a few days to investigate thoroughly and hopefully get to the bottom of the problem. I wondered if anyone had encountered a similar problem and might be able to suggest a cause?
    PS I've been lent an A6 Avant - wish my car's steering was as good!
  2. Re: Security problem
    Dec 2007
    i had this problem once
    the kids were messing with the key
    also if its in your pocket and u sit on it it can do it aswell
    maybe not you problem bug bugged me for ages
  3. Re: Security problem
    Jun 2007
    Quote Originally Posted by bez101 View Post
    No not the problem here for certain - no kids in the house and it's not possible to open the windows from the key.
  4. Re: Security problem
    Sep 2009
    Bristol
    Quote Originally Posted by penrecon View Post
    Are you sure - I thought it was a standard feature that the windows could be opened with the key.
  5. Re: Security problem
    Jun 2007
    Quote Originally Posted by thescouselander View Post
    I don't think so, I can't check with the handbook as that's in the car which as I said is at the dealer, I mentioned this when there and wasn't contradicted by the 2 people who heard me say it.
    At the time of the first 2 instances of the boot opening the car was not set to open the boot from the key and in any case the first time the key was well out of range of the car. It has been recently set to open from the key, but I don't believe it could have been operated accidentally.
  6. Re: Security problem
    Dec 2007
    hold the unlock button in dont relese it and the windows will go down
    hold lock button and they close
  7. Re: Security problem
    Jun 2007
    Is that standard, or does it have to be programmed? Do both front windows open?
  8. Re: Security problem
    Jan 2010
    Weymouth, Dorset
    Convenience opening was disabled by default on my A4 but closing was enabled. You should be able to enable / disable from the mmi.
  9. Re: Security problem
    Aug 2008
    Conveience open can be set for fronts or fronts & rears
    i turned it off after my 3yr old dropped the windows a few inches the night it poured down! Took ages to dehumidfy the carpets!
    Can i suggest you try the spare key and put this one way away from the car. It could be a fault with the key buttons doing this? (just a wild thought but always expect the unexpected)
    Merc ML's have a recent instance of boot opening randomly
  10. Re: Security problem
    Jun 2007
    Quote Originally Posted by sunil1234 View Post
    Having thought about this carefully, I am not at all sure it could be the key, since at the time of the first 2 instances when the boot opened, convenience opening from the key was not enabled. Although convenience opening for the front wiindows is enabled, when the windows opened as well, the car was still locked.
    The dealer is still on the case and looking at control units at present - I have nothing but praise for them (Tetbury Audi), as they have made it clear that they want to find the problem, have lent me an A6 to keep as long as it takes.
  1. Help! Clicking window problem.
    By dcorcouk in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-03-2008, 09:58 PM
  2. Mark 4 Golf Starting problem.
    By Oztrexx in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2008, 01:08 AM
  3. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  4. 100km problem Golf V
    By markaus in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-01-2007, 10:03 AM
  5. Audi A8 confirmed as Britian's most secure car
    Last Post: 03-07-2004, 08:29 PM
