Thread: B8 S-Line Xenon Part Number Difference? Confused?
  1. B8 S-Line Xenon Part Number Difference? Confused?
    May 2008
    15 Post(s)
    What's the difference between The D1S and the D3S? I've been going through the forum and some people recommend the D3S and some the D1S for the Philips XenoEcoStart?
    My right side light has gone off and I am going to replace myself as Audi are charging £100/hr just to check!
    Can anyone please help and advise where I can buy these from and what I should be buying?
  2. Re: B8 S-Line Xenon Part Number Difference? Confused?
    Bratty Guest
    I cannot answer your question! But just as a tip, I would swap the bulbs over to see if the fault transfers so that you deffo know its a bulb and not the xenon control module.
    They only takes 5 mins (or less!) to swap them and might save you wasting money on something that is not required.
    This might help https://www.vwaudiforum.co.uk/forum/s...-Bulb-Changing
    Dunk
  3. Re: B8 S-Line Xenon Part Number Difference? Confused?
    May 2008
    15 Post(s)
    Excellent Idea! Thanks for that
  4. Re: B8 S-Line Xenon Part Number Difference? Confused?
    May 2008
    15 Post(s)
    Hi Bratty, just seen your really helpful images, how easy is it to get to the fixing scews inside the bay and how much can the headlights come out by?
  5. Re: B8 S-Line Xenon Part Number Difference? Confused?
    Bratty Guest
    Quote Originally Posted by Sheroo View Post
    I have a spare set of headlights!! and the only reason that I have taken the pics like that, is that I no longer have the car that they were attatched too
    You can do the job with the lights in-situ.
    Even if you feel the need to remove the lights that is a ten minute job (but can scratch the lens/paintwork because its a bit tight and if you force them
    Dunk
  6. Re: B8 S-Line Xenon Part Number Difference? Confused?
    May 2008
    15 Post(s)
    Great advice from Bratty, thanks. I switched the bulbs and thankfully it is just the bulbs that have gone. It was a bit of a pain removing the screws without the correct tools and the cable was a bit fiddly, but all things considered it is quite an easy job even for a novice like me.
    Now I just need to buy a D3S bulb.
  1. Confused over age/milage to choose with S-Line
    By darren_mcneill in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-02-2011, 08:11 AM
  2. Part Number & Specs For S-Line Alloys
    By jUsT2eXy in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-07-2010, 11:52 AM
  3. Difference on S-line and sports suspension?
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2009, 12:59 PM
  4. Replies: 2
    Last Post: 22-09-2008, 08:47 AM
  5. S-line shock difference with non S
    By a4_jim in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-08-2008, 03:54 PM
