Thread: AFS inoperative see owners manual
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. Re: AFS inoperative see owners manual
    #21
    Norfolk
    You could put the code read result on here and see if anyone recognises something.
    Dealers can usually lose the cost of their scan if they are doing the repair work. Many faults with these lights can only be fixed by a new light unit.
  2. Re: AFS inoperative see owners manual
    #22
    Jun 2010
    Birmingham
    Quote Originally Posted by martin1810 View Post
    Reason I asked if they would accept my Ross Tech report because Im in dispute with the dealer I purchased the car from and need evidence of how much the work will cost. So I really dont wanna pay the £80 for thier machine to tell me the same results just in case the dealer starts playing hard ball and refuses to pay out.
  3. Re: AFS inoperative see owners manual
    #23
    Norfolk
    In that case I would go to another dealer and ask to have a word with a master tech. Show him the Vag-com print out and see what he thinks.
  4. Re: AFS inoperative see owners manual
    #24
    Jun 2010
    Birmingham
  5. Re: AFS inoperative see owners manual
    #25
    Jun 2010
    Birmingham
    I have done a more detailed test on the headlights using Vag Com. Results below....
    Test 1: control circuit for curve lighting warning light
    Test 2: Dynamic cornering light - position left
    Test 3: Dynamic cornering light - position right
    Test 4: Headlight cornering light - adjusting to center position
    Test 5: Headlight range control - adjusting to delivery position
    Test 6: Headlight range control - adjusting to lowered position
    Test 7: Headlight range control - adjusting to raised position
    Test 8: Static cornering light left - down/dim
    Test 9: Static cornering light left - up/bright
    Test 10: Static cornering light right - down/dim
    Test 11: Static cornering light right - up/bright
    Please can anybody shed any light on these results, and what do they mean? i.e why is there 4 Loads and what do the percentages mean.
    Many thx
    Mark
  6. Re: AFS inoperative see owners manual
    #26
    Norfolk
    I think you will have to ask ross-tech if they know exactly what the load figures are and what they mean. My best guess is they are loads for the four motors. Reading left to right.
    Left up/down. Right up/down. Left swivel. Right swivel. I also assume the figures are telling you that all the motors are ok. The problem seems to be the fault code which said left swivel position sensor. These lights can,t be repaired but it might be worth taking off the left headlight and having a good look. The diagnostics can't tell the difference between a faulty sensor and a damaged wire sometimes. I think a dealer would just change the left headlight and see what happens. Not funny at £500 each
  1. In Car Owners Manual (and MMI manual) on your PC
    By ScottyUK in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-09-2011, 08:08 PM
  2. New Owner's Manual ... and a few gripes
    By terrytg41 in forum Golf MK6 - 2009 - 2013
    Last Post: 31-03-2010, 11:10 PM
  3. Passat B5.5 wagon owner's manual
    By John in Norway in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2009, 11:01 PM
  4. Bora Owner's Manual
    By Drakis in forum Bora - 1998 - 2005
    Last Post: 12-06-2007, 02:28 PM
