Thread: ABS + ESP icons....again.
  1. ABS + ESP icons....again.
    Jun 2007
    Woking, Surrey
    Recently had both the abs and esp icons light up. Checked out the forum and found Paul46's entry on the subject. (25.04.2007). Booked car into local garage and they found, as with Paul, the brakelight switch was at fault and replaced. But.......the icons are still coming on when car is used first thing each day. If i turn off engine and restart, no warnings ! Any ideas what else problem could be? Car booked in next Tuesday so would be handy if i could suggest to garage what to check. Cheers.
    May 2007
    knee deep in clunge
    14 Post(s)
    Press the check button when it happens,if low level comes on top it up also check battery from cold start as any drop in voltage will cause the red warning light to come on.There is also a repair to the 75x wiring(cranking supply)were a relay is fitted to reduce low voltage (you wont notice it)signal to the dash.Then again the switch may not be sat correctly.
  1. Warning icons on dash?
    By paul46 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-05-2007, 07:46 PM
  2. 1991 V8 quattro dash display icons
    By MattPryce in forum A8 - S8 - V8
    Last Post: 08-04-2007, 12:38 PM
  3. Warning Icons
    By Markyle in forum Audi A4 - Archive Topics
    Last Post: 12-02-2007, 06:29 AM
