Thread: 2.0TDi Sline 2007 Sportback Common problems to look for ?
  1. 2.0TDi Sline 2007 Sportback Common problems to look for ?
    Hi looking at purchasing this car this week just wanted a heads up from you guys it has covered 44k.
    Thanks Sunny
  2. Re: 2.0TDi Sline 2007 Sportback Common problems to look for ?
    Feb 2010
    Cambridge UK
    Quote Originally Posted by Sunny View Post
    Thanks Sunny
    Not an expert, but there's the usual checks for things like coloured smoke out the exhaust (if it's humid there will be a lot of visible water vapour, but this is fine), check for mustard around oil cap. Ie basically that the oil system is sealed and working fine.
    ABS control unit is a common failure, or one of the sensors associated with it at least - first check that the ESP warning light hasn't been bypassed to disguise the problem by turning the ESP off - an amber warning light should show in the dash. Once you've checked that's working then any problems will become apparent on a spirited test drive - when mine was on it's way out the traction control and ESP would cut in overly aggressively, especially exiting roundabouts. Since getting it fixed the TC is unnoticeable to this average driver - it just seems to stick to the road.
    Problem is the sensor can go at any time really - honestjohn basically recommend haggling 1.5k off the price by default as that's the cost of replacement. I also bought an extended warranty that covered it.
  1. A4 2.0tdi 140 55 reg, problems
    By isaach in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-09-2009, 09:58 PM
  2. Please Help 2007 A3 Sportback 2.0 tdi s-line broke down an hour after collecting it
    By paul the 6th in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-07-2009, 10:32 AM
  3. DTC code 5317 on 2007 2.0TDi 170 Quattro
    By wizbongre in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-05-2009, 10:48 PM
  4. 2007 B6 Passat estate 2.0TDi SE Service/Workshop Manual
    By Dtwo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-04-2009, 07:23 PM
  5. s3 common problems to look for !!
    By ian in forum Audi A3 - Archive Topics
    Last Post: 17-01-2007, 10:14 AM
