Thread: Immobiliser Activated Golf Mk5
Results 1 to 10 of 20
  1. Immobiliser Activated Golf Mk5
    Jun 2006
    Hi All,
    I really hope someone can help.
    Tried to start my car after going to the shops the other day ant the immobiliser acvtivated light came on and it will start but run only for about a second.
    I've tried my spare key in case I'd damaged the original but no joy, it still won't run.
    If I leave the ignition on, I then get the emission workshop light then the engine workshop light, but as I say the engine starts and I had no problems right up until the immobiliser issue.
    I've tried disconnecting the battery and leaving the key in the on postion for 20 mins 2 suggestions I was given) but nothing changed.
    Really hoping someone can help.
  2. Re: Immobiliser Activated Golf Mk5
    Sep 2009
    London
    Where are you located? you may need to get the immo paired with the keys again as for some unknown reason it has had a memory wipe.
    2004 golf mk5 with retrofitted: cruise control, MFSW, Highline clock diplay, angel lights.
  3. Re: Immobiliser Activated Golf Mk5
    Jun 2006
    Thanks for responding.
    I've had a VW assist tecchie look at it as a favour and when he plugged his kit in, he said that the immobiliser and the ECU were unpaired but also that he was getting an error message that there was no communication with the ECU.
    Its going into the main dealers on Saturday now so god only knows how much this is gonna cost.
    Just praying that the release code only VW can generate will sort it out.
    By the way I'm in Stockport
  4. Re: Immobiliser Activated Golf Mk5
    peter cresswell Guest
    Join the cl, but immobiliser unsepcified fausts, abs faults, electric window faults etc etc etc.
    Its a lovely car but once I have fixed the latest massive repir bill its goibg to someone else and I will revert to a ford that I can dump when it goes wrong or VAUXHALL WHICH PROBALY WONT GO WORNG IN MY EXPERIENCE WITH COMPANY CARS
    best of luck
    Pete
    ub..... Whne I had my ecu interrogated there were 16 error messages. The lastes hit is turbo overboost and then then immediate loss of 100bhp until you switch off and restart. They have not a c;lue what is causing this. This car is too complicated byhalf. I had your problem nd it was fixed in 2 mins free of charge andthis at least has never comeback
    Quote Originally Posted by sufc38 View Post
  5. Re: Immobiliser Activated Golf Mk5
    Jun 2006
    Hi all,
    Quick update.
    Monday car went into main dealers and diagnostic test reported multiple fault codes but dealers unable to identify fault, so they said it was put on a factory test overnight after checking all the wiring from the ecu to the immobiliser and ignition.
    Tuesday sames fault codes reported by latest test, so these were then sent to Milton Keynes VW HQ where codes and problem with immobiliser are compared to european database with similar faults, and possible solutions reported back to dealers where my car is.
    Wednesday No resolution from the suggestions from Milton Keynes, so car now having another diagnositic run by a German technician online from germany, if they still don't get a result, then a technician from Milton Keynes will come to inspect car and if that fails then a German engineer comes to inspect it.
    Glad I'm not paying for this lot.
  6. Re: Immobiliser Activated Golf Mk5
    Jun 2006
    Finally they've diadnosed the fault on but only after borrowing an ECU of another car.
    The ECU has gone and I'm being quoted £1100.00 to replace and fit it.
    The dealers tried to get some goodwill from VW but they said no due to the fact that the car is six years old and the last two services were not main dealer.
    They reckon at the dealership that it's five hours labour to replace and recode etc which seems a bit excessive to me (does anyone know how long it actually takes?), although the guy has discounted the labour from £85. per hour (OMG) to £60.00 (still OMG).
  1. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 17-09-2009, 08:43 AM
  2. The fastest-accelerating volkswagen yet: The new golf r
    Last Post: 15-09-2009, 08:29 PM
  3. First Facts on the Golf BlueMotion:
    Last Post: 13-08-2007, 07:08 PM
  4. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
