Thread: Leaking coolant from radiator..
Results 1 to 10 of 11
  1. Leaking coolant from radiator..
    Aug 2009
    Liverpool UK
    It appears I have a leaky radiator, as I'm losing coolant quite rapidly
    Due to the other multitude of faults I've had to pay for repairs on, I can't afford a new radiator just at the mo.
    I've been recommended to use 'rad weld' as a short term measure to seal the leak, until I can scrape enough dough together to pay for a new rad (bang goes the sat nav unit)
    Can anyone tell me what problems I may incountet if I pour it in the coolant system?
    Also, I've bought pink 50/50 coolant from halfords. Is this ok for my 06 2.0tdi passat?
  2. Re: Leaking coolant from radiator..
    DSG4ME Guest
    Bite the bullet mate, you don't want rad weld in the rest of the cooling system, get the yellow pages out and see if you can get it repaired, is it leaking at the core or the tanks or the hoses?
  3. Re: Leaking coolant from radiator..
    Aug 2009
    Liverpool UK
    Quote Originally Posted by DSG4ME View Post
    I had a guy look at it, who just said it was leaking from a small hole at the bottom of the radiator , from what he could see.
    He was meant to be getting back to me with a price for a new one, although at that stage I didn't know they could be repaired
    anyone want to guess at the approx cost of repair or replacement?
  4. Re: Leaking coolant from radiator..
    DSG4ME Guest
    GSF or Euro Car Parts will be best for price on a new unit.
  5. Re: Leaking coolant from radiator..
    Mar 2009
    York
    Dealer price around £300 including fitting, independent varies between £220-260 in my experience. I had the same leaking problem and fortunately for me it was done under warranty. Think there's a weak spot on some radiators.
    The actual cost of a radiator isn't too much I don't believe, it's the labour in putting it in, as my independent informed me they have to 'drop' the radiator out of the bottom of the car - so not really a DIY job!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  6. Re: Leaking coolant from radiator..
    Aug 2009
    Liverpool UK
    Quote Originally Posted by patomlin76 View Post
    Diy is not an option, as my knowledge of cars starts and stops with seeing the coil symbol light up and saying "FFS not again"
    While I wait for my engineer guy to get back to me with a price, can I still drive the car as long as I keep the coolant topped up?
  7. Re: Leaking coolant from radiator..
    Mar 2009
    York
    yes - my independent said you are fine to keep topping the coolant up (with the right VW spec one of course - think it's got a pinkish tinge to it) Just keep an eye on the coolant - with my problem the coolant sometimes dropped quite quickly over a few days, sometimes stayed quite level for a week... odd.
  8. Re: Leaking coolant from radiator..
    Aug 2009
    Liverpool UK
    Indeed, this is the same with mine. Didn't appear to leak for a whole day, then leaked about half a pint in hours!
    Also, just to fuel my paranoia, I'm concerned I may have caused further damage as when I first got the 'low coolant' warning, I topped up with water to get me to the garage, but fear I put too much in (above half of the 'ball')
    Am I doomed?
  9. Re: Leaking coolant from radiator..
    Pembrokeshire
    22 Post(s)
    no, that wont hurt. at worse it will throw some coolant out of the cap.
  10. Re: Leaking coolant from radiator..
    Aug 2009
    Liverpool UK
    Phew!
    Thanks so far for all your helps, guys
    As you can probably tell, I'm pretty crap at this car malarkey
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. Please Help Weeping turbo and leaking radiator
    By newb1e in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-05-2010, 10:55 PM
  3. A6 2.5 tdi Radiator leaking & Coolant lightt
    By raf_man in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 05-04-2009, 12:09 AM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. How To change radiator in 1.9 tdi
    By Shaun. C. in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-05-2008, 07:46 AM
