Thread: Pleeeese help asap
  1. Pleeeese help asap
    Mar 2010
    Cheltenham
    Driving home today just got on the motorway and went to overtake and i had power but not much of it atall
    Slowed down but basically had no power between 2k/3k it was revving but not picking up speed,
    Any ideas? And is it ok to drive?
  2. Re: Pleeeese help asap
    Pembrokeshire
    22 Post(s)
    a revving engine, but no increase in speed is usually a sign of a failing clutch. i would get someone to test drive it for you to confirm though. you will also probably need a new dmf. (dual mass flywheel ). best not to drive it really, as then you will definately need the dmf, and it wont get better, only worse. expect a bill approaching a grand if i am correct in my online diagnosis, from your description of events.
  3. Re: Pleeeese help asap & New gears question
    Mar 2010
    Cheltenham
    Thanks for that but i actually let the car heat up on the drive and took it out the same night and it was fine.. very weird!
    Next question :-)
    Dropping through the gears from 3rd to 2nd sometimes it makes a really horrible noise, its not the clutch like sometimes you grind it but more a metal on metal squeak and it can do it quite loud too, is it me or can I do something to stop it?
  1. Door lock advice needed asap!!!!!!
    By Jayc20xe in forum Golf MK4 - 1999 - 2004
    Last Post: 08-08-2009, 08:37 PM
  2. car nt idleing - plz let me knw asap
    By faz112 in forum Chat - Anything with wheels
    Last Post: 12-05-2008, 07:45 PM
  3. help Needed Asap!
    By SHAZA4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-03-2008, 06:28 PM
  4. Help ASAP fitting turbo to tdi passat plz
    By BICCUS1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2007, 07:49 PM
