Thread: golf vr6 blue smoking slightly?
  1. golf vr6 blue smoking slightly?
    Mar 2009
    hi there i have a 97 golf mk3 vr6 when i sit it stationary it sometimes blows out little blue smoke and if i rev it high it blows some out, its done 137k is it just age showin hope it nothin to bad oil level always maintains quite wel any help welcome thanks
  2. Re: golf vr6 blue smoking slightly?
    Jan 2009
    towcester northants
    poss valve stem seals
    check breathers
  3. Re: golf vr6 blue smoking slightly?
    Mar 2009
    are the stem seals hard /expensive to change? Were are the breathers located again hard job? Thanks
  4. Re: golf vr6 blue smoking slightly?
    Jan 2009
    towcester northants
    nothings easy/cheap to do on these engines as you have to remove so much to do anything
    cams out to do stem seals req special tools to do
    breather system quite easy to check
    little valve coming off front rear of cam cover and follow hoses
  1. Replies: 0
    Last Post: 15-08-2009, 07:48 PM
  2. More economical, more practical: The new golf plus bluemotion:
  3. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
  4. Question Bought a 1998 Golf VR6. What are most important points to keep in mind?
    By BA005 in forum Golf MK3 - 1993 - 1999
    Last Post: 13-05-2009, 09:58 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
