Thread: Brake Breeding & pad change.
  1. Brake Breeding & pad change.
    Mar 2008
    Stockton
    Can anyone advise me what order to bleed my brakes in? also am i right in thinking it's a right hand windback tool i'll need to retract the piston? thanks
  2. Re: Brake Breeding & pad change.
    131 Post(s)
    1976 Post(s)
    There is no particular order in my opinion but VAG say furthest away from the master cylinder first and work around but I just do the rears first and then the fronts. DO NOT under any circumstances allow the reservoir to run dry or you will not a get good pedal back without do a Basic Settings pressure bleed. Yes the wind back tool is righty tighty.
  3. Re: Brake Breeding & pad change.
    Mar 2008
    Stockton
    thanks, can vag-com be used to bleed the system?
  4. Re: Brake Breeding & pad change.
    131 Post(s)
    1976 Post(s)
    Yes, as long as it is a registered copy.
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. rear brake pad replacement
    By 1100xx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-04-2008, 09:19 PM
  4. Brake pad life and warning light
    By Stuart W in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2007, 06:43 AM
  5. Rear Brake pad change.
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-07-2007, 03:24 PM
