Thread: petrol filter
  1. Thumbs down petrol filter
    njb44 Guest
    How do you and how easy is it to change the petrol filter on a mk3 golf any special tools req.
    I've changed the fuel filter on both MKII & MKIII GTI's. Not sure which golf you have. The filters have a metal crimp ring that holds the pipe to the filters. You can get them off with a pair of pliers by squeezing the raised portion. When refitting I used jubilee clips instead. Take all the usual pre-cautions i.e doing it in a well ventilated area and no smoking. After fitting the new filters I turned the ignition on so the electric fuel pump would prime the filter a couple of times. Then started the car and leak cheched it.
    Hope this helps Boardboy
    njb44 Guest
    OK thanks for your help
    how does the unit come out taken the top off, err next step
    its a 1993 mk 111
  1. petrol in diesel car
    By futsysmids in forum 80 - 90
    Last Post: 15-06-2007, 10:49 AM
  2. DISASTER!!! Put petrol in my TDI.
    By jasear in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-06-2007, 03:07 PM
  3. 2.0 petrol using oil
    By sompop in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-06-2007, 08:17 PM
  4. Audi a4 petrol
    By catseyes9 in forum New Member Introductions
    Last Post: 17-09-2006, 01:43 PM
  5. MPG petrol v diesel.
    By VAG fan in forum Passat - Archive Topics
    Last Post: 19-08-2006, 06:10 PM
