Thread: cruise control
Hybrid View
  1. cruise control
    May 2010
    Devon England
    the cruise works fine on my car but i have a question or to here goes,
    when i switch mine on (i leave it on all the time) if im using it or not i always have the green lamp on the dash, i thought it should only light up when you set the speed, does anyone know if its right or not?
  2. Re: cruise control
    Jul 2008
    High Peak, Derbyshire.
    Yes - the Green Light should always be on when the cruise control is on. It only goes off if you switch it off using the rocker type switch on the indicator stalk.
  3. Re: cruise control
    May 2010
    Devon England
    Ideal thank u mate
  4. Re: cruise control
    mjom89 Guest
    Mine only lights up when you set the speed. The rocker on top is always switched on.
    Maybe its an age thing? Mine is a 2007 (57)
  5. Re: cruise control
    May 2010
    Devon England
    Ive driven a 57 plate that worked the same as yours that's what made ask, it could be am age thing , but the rocker switch on mine is a little bit sticky and thought that could be a part of it, I think I will leave it alone while it works lol
  6. Re: cruise control
    Jul 2007
    Matlock
    if my cruise control switch is in the "ON" position, the green lamp only illuminates when i set the speed, and mine is a 58 plate.
  7. Re: cruise control
    Jul 2008
    The varying replies have had me rushing to my handbook!
    Mine says (an 05 plate) that when you switch the rocker switch to "on" the green light comes on. You then set the speed.
    Essentially the green light shows that the system is on regardless of whether the speed has been set.
    I wonder if they changed it with the later models.
  1. Replies: 21
    Last Post: 16-07-2015, 03:07 PM
  2. How To DIS AND CRUISE RETRO FIT b6+b7
  3. Coding of engine : witout cruise control
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-04-2009, 08:19 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
