Thread: A4 spongy brake pedal
Results 1 to 10 of 15
  1. Re: A4 spongy brake pedal
    Pembrokeshire
    22 Post(s)
    sounds like the servo to me. try this. start engine, run for a few seconds then turn off. press brake pedal then release. press again etc.. how many presses before it goes hard ? hold pedal down and start engine. does the pedal immediately go soft ?
  2. Re: A4 spongy brake pedal
    Aug 2008
    Thanks for that........i started the engine and then turned it off, pumped the brake pedal bout 2 or 3 times and it went rock hard. i then started the engine and the pedal went soft quite quickly but again a fair bit of travel.
    today i slammed on the brakes whilst travelling down a slip road and there was a bit of travel, but almost immediately i took my foot off the brake pedal and slammed on again and the brakes were very sharp ( made sure that no one was behind obviously!! ) . it really is spoiling what is otherwise a really good car that still drives well. as i said, i've just replaced the brake master cylinder with no joy.
    any more ideas?
  3. Re: A4 spongy brake pedal
    Pembrokeshire
    22 Post(s)
    i think you either have a faulty servo, or a vacuum leak somewhere. with the engine running, can you hear any hissing, especially when you wiggle the servo vacuum pipe, or any pipes connected to it
  4. Re: A4 spongy brake pedal
    Dec 2009
    South Africa
    I have the same car and the same feeling. The brake pedal feels very soft and travels quite a bit. But I does brake
    My vacuum is 100%, I say that because I still have some vacuum assist left (1 maybe 2 pedal depressions) in the morning before I start the car from the nights driving before the pedal becomes hard.
    My concern is why if I stand at a traffic light and keep the pressure firmly(hard) on the pedal it continues to go deeper and deeper until about 1.5inch from the floor? I've (replaced the old and) bled the system and don't lose a drop fluid!
    Is this normal? Is it air in the system? Is the master cylinder leaking? help?
  5. Re: A4 spongy brake pedal
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Possibly faulty Servo.
    Alan.
    VW T6 150 DSG Camper £££
  6. Re: A4 spongy brake pedal
    Oct 2010
    bridgend, s.wales
    [QUOTE=bvisser;562917]I have the same car and the same feeling. The brake pedal feels very soft and travels quite a bit. But I does brake
    Is this normal? Is it air in the system? Is the master cylinder leaking? help?[
    I HAVE EXACTLY THE SAME PROBLEM WITH MY 2003 POLO 1.9 TDI SPORT DID YOU GET ANYWHERE WITH IT?
    BEST WISHES
    Deryl
  7. Re: A4 spongy brake pedal
    Jun 2010
    New Zealand
    Sounds like your master break cylinder is passing you wont be loosing any fluid. You will need to have it serviced ... re kitted the piston and sleeve have become worn and break fluid is passing and not holding pressure.
  8. Re: A4 spongy brake pedal
    Dec 2009
    South Africa
    Hi Deryl & BrandonA4
    I still have the exactly the same symptoms and the brakes work fine. Have also checked the ABS on loos gravel so ensure all the wheels brake and on tar to see if its pulling to a side. (so there is nothing else wrong with my brakes except the slow leaking MSB).
    From my mechanical understanding of the system (got the ETKA diagrams of the net) BrandonA4 is correct its the MBS. So in my opinion its not critical and when it worsens I will replace it.
  9. Re: A4 spongy brake pedal
    I do have the same issue with my 1996 B5 1.8T. The circuit has been bleed, the MBS has been swapped but the spongy brake pedal is still there, only getting firmer after 2 or 3 presses. Is it possible that the ABS module isn't sealing something correctly?
    Can anyone help me with a list of steps that should be done in order to locate the problem?
    Best regards,
    Nuno
  1. spongy brake pedal on allroad
    By 9eleven in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-07-2017, 01:13 AM
  2. Wishbone Front / Rear Axle Bush which brand
    Last Post: 23-05-2009, 12:27 AM
  3. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
