Thread: passat 1.8t fault codes p1654 p0411
  1. passat 1.8t fault codes p1654 p0411
    Apr 2009
    uk
    my passat has thrown up these codes, p1654 electronic instrument panel and p0411 secondary air injection system faulty flow. car still drives fine,,engine light is on though,any ideas??
  2. Re: passat 1.8t fault codes p1654 p0411
    16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
    Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    Possible Causes
    • Fuel Pump Relay (J17) faulty
    • Hoses/Pipes to/between Components faulty/clogged
    • Secondary Air Injection Pump (V101) faulty
    • Secondary Air Injection Pump Relay (J299) faulty
    • Secondary Air Injection Solenoid Valve (N112) faulty
    Possible Solutions
    • Check Fuel Pump Relay (J17)
    • Check Hoses/Pipes to/between Components
      • Check Secondary Air Injection Hoses/Pipes for Carbonization
    • Check Secondary Air Injection Pump (V101)
    • Check Secondary Air Injection Pump Relay (J299)
    • Check Secondary Air Injection Solenoid Valve (N112)
    p0411 - Volkswagen:Please check DTC Memory of control panel ECU
    This is a fault that normally tells you to scan the cluster for faults, this fault normally is a problem with a faulty coolant temp sensor. You will need a factory type scanner or VAG-COM program to clear the fault in the cluster. The Coolant temp sensor is a two part sensor i.e. four wires, two wires go to the cluster and two to the engine control unit. The cluster side probally failed or went open/closed short which triggered the fault.
  3. Re: passat 1.8t fault codes p1654 p0411
    Norfolk
    What engine code. Without knowing which engine the codes don't mean alot. You would be better off getting a vag-com scan as OBD codes are not reliable for diagnostics.
  1. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  2. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
  3. Some advice please needed on wheel offsets - ET37 vs ET35
    By Staz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-12-2007, 05:48 PM
  4. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
  5. 03 Sharan TDI Fault codes
    By mistuart in forum Touran - Sharan - Caravelle
    Last Post: 15-11-2007, 09:52 PM
