Thread: Passat Estate Tailgate Locked - Unable to Open :-(
  1. Passat Estate Tailgate Locked - Unable to Open :-(
    Aug 2007
    Please could someone help me to open the tailgate on my 2002 passat estate.
    I have always had to use the key to open it, which was fine. Then a few weeks ago I had to start flicking the switch in the driver's door to loosen it, before using the key to open it. Now even this doesn't work and I am stuck with the tailfgate locked all the time. When I flick the driver's door switch I hear the electrics but no clunk as used to happen when the tailgate loosened.
    I have wedged a bit of the trim off and had a look but cannot see anything obvious.
    All suggestions greatly appreciated.
    Many thanks,
    Ted
  2. Re: Passat Estate Tailgate Locked - Unable to Open :-(
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by FatherTed View Post
    Many thanks,
    Ted
    Search and yea shall find........
    https://www.vwaudiforum.co.uk/forum/s...archid=1690247
    Nothing to see here, move along..
  3. Re: Passat Estate Tailgate Locked - Unable to Open :-(
    Aug 2007
    Thanks - but can anyone tell me how to open the tailgate ???
  4. Re: Passat Estate Tailgate Locked - Unable to Open :-(
    Mar 2008
    Just Cumbria now.
    It's all there if you look....
    https://www.vwaudiforum.co.uk/forum/s...ight=boot+lock
  5. Re: Passat Estate Tailgate Locked - Unable to Open :-(
    Aug 2007
    Thanks for that - the rod seems to be disconnected as I could not see it when I took as much of the trim off as I could. I will go and take another look.
    I found two screws in the hand holds - but could not see the other two - anyone know where they are?
    Many thanks,
    Ted
  6. Re: Passat Estate Tailgate Locked - Unable to Open :-(
    Aug 2007
    croydon,surrey
    Many thanks,
    Ted
    there isnt any just 2 pull hard and it will come off
  7. Re: Passat Estate Tailgate Locked - Unable to Open :-(
    Aug 2007
    Thanks - I managed to finger the boot open after breaking into the lower part of the trim.
    So now I have the trim off and I can see what looks to be the frayed end of a cable that looks like it should connect to the end of the key barrel - see the photo.
    Can anyone explain how I can repair this / how it is meant to fit together / what parts do I need to buy.
    Very many thanks,
    Ted
  1. Replies: 0
    Last Post: 03-03-2008, 08:19 PM
  2. Tailgate open indicator
    By Guitar.joe in forum Alhambra
    Last Post: 10-11-2007, 01:21 PM
  3. Vw Passat 4motion Estate Voted Towcar Of The Year 2007
    By Ben in forum Chat - Anything with wheels
    Last Post: 26-08-2007, 07:35 AM
  4. Passat Estate: can't open boot.
    By Steve E in forum Chat - Anything with wheels
    Last Post: 27-07-2007, 12:08 PM
  5. Passat Estate Tailgate Problem
    By willy100 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-05-2007, 09:23 PM
