Thread: Fuse for stereo
Results 11 to 20 of 21
  1. #11
    Apr 2007
    Quote Originally Posted by Flash2 View Post
    You said you could eject discs from the unit but it wont turn on. That sounds to me like you don't have voltage on the ignition feed wire on your radio plug. I could tell you which wire that is but your going to need some way to test the wiring on your car if you want to try and fix the problem yourself.
    (http://www.maplin.co.uk/search.aspx?...Menu=y&doy=5m6)
    Another thing to try is join the red and the yellow wires on the radio wiring loom together. Leave the yellow wire connected, unplug the red one and reconnect it to the yellow so both are powered from the same wire on the vehicle's wiring loom. The unit may work now, but it wont switch off with the ignition.
    Regards - Jim.
    What would you advise if the red wire had no voltage on it as i think that is the case in my car?
    As a side note when I joined the red and yellow wires, the remote alarm wouldn't work. After separating them, the remote alarm central locking worked fine.
    Life is not boring once you drive a bora
    May 2007
    17 Post(s)
    Check all the fuses on the dash fuse box. Did you have an original VW radio? Did it switch on and off via the ignition key? VW radios can be switched on even when the key is not in the ignition, but turning the ignition on and off again should switch the radio off.
    As for your alarm problem, have a look at the power connector for the radio (the ISO plug on the vehicle wiring loom). You will see a heavy brown wire, 2 heavy reds with a black stripe above the brown. You should also see two thin orange wires. The orange wires are for the vehicles CAN BUS. Make sure there are no wires from the radio connected to them. If there is disconnect them and try the remote again.
    Jim.
  3. thanks
    Apr 2007
    Thanks Flash, I checked the fuses again and a 10amp one was blown. Changed it and then swapped over yellow and red from stereo and bob was my uncle!!!
    The alarm also works fine now and what can i say but im a happy bunny (without sounding queer)
    May 2007
    Just tried the old VW stereo. Turned the ignition and stereo on then removed key. Unfortunately stereo stayed on.
    There must be a fuse for this ignition feed. I checked all the fuses in the panel the other day and they looked fine. If anyone could tell me the exact fuse that'd be interesting.
    Frank
    Apr 2007
    Do you have a diagram on the fuse box lid? If so, the ones that blew while I was experimenting were the ones with book images on. Hope that helps.
    May 2007
    That makes sense. I'll try them again. You'd have thought all these fuses would be labelled properly....
    If no luck, it's in the lap of the Argos stereo fitters! I'm sure they'd be unable to solve a car specific problem like that....
    Frank
    May 2007
    17 Post(s)
    Quote Originally Posted by keano16 View Post
    Your welcome. Glad I could help.
    Perhaps you could tell Frankie the location of the fuse you replaced before the Argos guys show up
    Jim.
    Apr 2007
    Hey Frankie,
    The ones i changed were 10amp and 25amp with book images on them, Yeah they could make those icons more informative, anyhow let us know how you get on.
    Oct 2005
    Quote Originally Posted by frankieboy View Post
    Frank
    It's probably obvious but it sounds as though you're connected to constant live rather than switched live.
    I've briefly skimmed the thread but I can't see any mention of what car this is you're trying to install a stereo into.
    EDIT: Found out it's an 03 Bora - just searching for wiring diagrams now.
    May 2007
    The argos fitter did bloody well. Wired up the bare aerial to the stereo - perfect reception. He replaced a fuse -annoyingly i wasnt there. Id love to know which one it was. No it turns off and on with ignitionm.
    Unfortunately he couldnt get the connects2 sony to vw steering wheel adapter to work. I'm going to send it back. The question is, do I get replacement and try to fit it myself or just get a refund and take it to a car audio place and get them to mess around installing one? I know it's petty but I really want to keep the steering wheel controls!
    Frank
  1. which fuse???
    By cookie_monster in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-10-2007, 12:54 AM
  2. How much can the fuse box take?
    By jabba2020 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 08:14 PM
  3. ECM Fuse blowing
    By mikespain in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2007, 01:08 PM
  4. fuse box
    By vwgolfse in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-03-2007, 03:41 PM
  5. Fuse box
    By M4YTY in forum Passat - Archive Topics
    Last Post: 02-03-2007, 11:37 PM
