Thread: windows
  1. windows
    Jul 2007
    Hi guys n gals..
    bought a 1998 gti 8v... IMMACULATE!!! and im not kidding for 500 notes...
    the only problem i have with the car- which i was aware about when i bought it ,is....
    i can hit the elec window switch on drivers side- and that takes the pass side window down, as it should.. if i hit the button for it to go back up- it wont budge, but if i use the switch on the pass side- it works...
    and as for my drivers window- that doesnt work at all..
    both rear windows go up and down fine... checked all internal fuses- none popped... where else do i start to look? thanks
  2. Re: windows
    Mar 2008
    High Wycombe
    With the one which won't work at all, take the door card off and see if the cables form the regulator are broken (that's the cables which pull the window up and down, not the electrical wires)
    With the driver's side switch, check the switch and check the wires for any broken ones.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: windows
    Jul 2007
    ahaa!! .. found out when i unscrewed the rubber hose connecting the door the the main car, that a red/yellow cable was cut/disconnected...
    happy days, got soldering iron out and re soldered together- problem solved, no more frying in this weather
  1. The LAW and window tinting.
    By Ben in forum Vehicular windows, Glazing and Tinting
    Last Post: 26-05-2010, 09:47 PM
  2. Electric windows problem and retro fit
    By roryb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-07-2009, 08:25 PM
  3. 2 problems : windows and "electrical loss"
    By Godasso in forum Touran - Sharan - Caravelle
    Last Post: 17-04-2008, 11:02 AM
  4. Full enclousure windows
    By PASSAT SAJ. in forum Chat - Anything with wheels
    Last Post: 04-10-2007, 10:57 PM
  5. Mk3 Golf GTi 1996 Electric Windows Misbehaving - HELP!
    By AJKAS123 in forum Golf MK3 - 1993 - 1999
    Last Post: 21-03-2006, 02:41 PM
