Passat 1.6 TDI bluemotion
Anyway broke down at a garage with the "Depress Clutch" with no start.. after a few attempts to start no start and flashing glow plug light.
Garage have been useless they have said i need to replace a glow plug but upon scanning my car with a cheap sweetwize argos scanner i have found the fault code P0407.
Now with the key in ignition (not starting) i get no codes at all but once the engine is started and rescanned i get the error code.
The car is very lumpy at idle
Sometimes the Start/Stop system shows an error
And i have a ! next to a cruise control symbol where the mileage normally is on start up
Also when the car stops i get a noise coming from the throttle body as shown in video, i have taken the throttle body apart and nothing seems wrong with it at all i have removed the motor within it and tested with a battery spins freely
passat - YouTube
Also when i try clear p0407 fault with the engine running it sounds a tho the car is gonna stall
Any help
