So you mean new actuator G098 is not same or right for our car? or have to be adjust - remove Turbo and adjust actuator with turbo? Please give me information when you will find something.
Thank you.
Printable View
Thank you.
Ok, thank you. I am also provided my original actuator to servis for repairing and then i want replace back original one. I think new one without right setup (G98) not work right for my car where was G83
I have the same error turbochsrger actuator 1 stock, I ordered a new original from Germany, 400 € now wait to receive it to see how it is, do I have to calibrate it to be ok or is it plug & play?
Now they replace the G98 actuator and car behavior is completely different, now it's how should be 👍.
Funny thing after I drive aprox 1500km car went to safe mode again, 2 injectors burned up!!! The mechanic replaced 3 injectors and back flow pipes from injectors and after 100km again 1 injector burned and after that they replaced rest 3 injectors!?!?.
Don't know if mechanic made some mistakes during programming but it's little bit odd that injectors burned exactly in the same time like actuator...
Now I have felling that consumption droped for 0,5 l/100km.
Ok, and what was your original actuator 83 or 98?
I replaced old 83 to whole new 98 without any setup - it work better but not work properrly. I sent my original 83 for repairing (mechanical parts) now instaled back to the car - it is much better but still not perfect.
I asked some mechanich for help, so we will remove both turbos and adjust actuator with turbos out of car.
Did you some calibration or just change actuator? Did you calibrate actuator with turbos?
Thank you for information.
Thnx for info, my car is now around 208000km, for this car is from my opinion nothing and 6 injectors isn't small malfunction, that much from Audi. In 100000 km ; spoliler extraction failed, wheel bearing, direction handle broke down, actuator of turbo, injectors...
Mine is 209000km…
