Re: Diesel injector cleaner
I've used forte diesel treatment for a few years. I use it at every service, 6 months. It's supposed to be very good and not generally available at outlets.
Ben Williamson of Sports tech and regular Audi mag columnist uses it. It helps keep injectors clean giving a good burn and thus preventing clogging, on Turbos and EGR etc. You can always find it on ebay. RRP is about £11-12. Add to a low tank and add about £10 on top not a full tank. I apllied direct into my fuel filter last year as most servicing places will do.
Sometimes I add a splash of Millers DSP4. This is a cetane booster and has similar affects but not as good as Forte.
Marco
You might want to consider using the Shell Diesel V-Power once in a while as well. The V-Power products have big benefits over the normal fuel. They include injector cleaner, which may not be as good as some of the products Marco34 has mentioned, but used regularly enough certainly do the trick.
If you've had to replace 2 injectors, you will probably have some crap built up around your older injectors. Use the aforementioned products, then every 4th tank put in some V-Power Diesel or something like that.
Quote:
Originally Posted by
omegadirective
Yep I'll second that :beerchug: I do the same. I've filled with Shell V-Power more often lately for those free Ferrari cars :)
You should have ballanced and test the sparay pattern on the other 2 as well...
The free Ferrari toys are absolute cr*p. Cannot believe Ferrari endorse them. Having said that, I still have 3 of the cars to claim...
omegadirective
I wouldn't say there were that bad! They would look better red rather than the odd dark red. They look very red in the promotional photos :zx11:
Marco34
I wish he'd return my call.
He's my mate's brother and I want to get the car over to him to get the cambelt, clutch and general service but he's pretending to be ill at the mo :D
thefreak
Nice one... sounds a good place to go to me!!! :beerchug:
Marco34
Marco
Started to use the fortes diesel treatment on my car last year, very good stuff. :D
i use winns no idea if it works never had a prob with injectors so might work might not
New member from Finland reporting :)
I have used Sonax and CRC brand diesel system cleaners. I actually did a small test with my old A4 B5 w/ AFN engine. I had to drive 600km for work and I new I had to make the same trip again in a month. So the first time around I didn't use injector cleaner. The first time the average fuel consumption was 5.7l / 100km which equals about 1.25gals / 62miles = 50MPG. Before the next trip I added diesel system cleaner and my average was 5.3l / 100km which equals 1.167gals / 62miles = 53MPG
At least the cleaners sold here claim to raise the cetane figure of diesel, which leads to a cleaner burn and thus better economy and less hazardous fumes. I also noticed that the engine sounded alot smoother than before.
Now, obviously if these substances only increased the cetane figure your consumption would be back to normal once you've driven all of the substance out of the system. My average consumption went back up to about 5.4l / 100km once I had driven about 1000km and the substance had been used up. That's still 0.3l less than before so they do clean the system as well. With diesels, the smaller the drop size of the injected fuel the better it burns.
adamss24
How would I do that? It needs to be done in a garage, doesn't it?
thanks
I am having a similar problem, and have been told that changing the injectors may sort the problem.
Any ideas how difficult it is to do this? Is it something I could do myself, or is it a garage job? And where's the best place to get hold of them from?
I drive a golf 2001 gt tdi 115bhp by the way.
Before changing the injectors, you must at least try and see if that is the real problem through Vagcom.
I have read that sometimes it could be loose wiring connection to the injectors if you have done a cylinder head job or sometimes injector seals needing replacement. If it's neither one or the other, then may be Vagcom could signal a fault in the car cylinder which may indicate a faulty injector.
A good garage will try and test a new injector as replacement and see if that sorts the problem. It is quite costly to change one and I think you need to do it at the garage as it is a cylinder head job and need to use Vagcom again to read the codes after change.
