Audi A3 8P Drivers window not winding down and central locking issues.
Hi guys, I'm experiencing some new issues with my A3 8P, 2009, that I hoping some of you may be able to help me with. The biggie for now is the drivers window not going down. I think it randomly started some time this week. Pressed the window switch to roll down the window and nothing happened, continued through out the week and is currently doing the same. I can roll down/up the passenger side window from the window button switch at the drivers side.
I had an issue with the window regulator on the passenger side not that long ago, but that gave more obvious signs of what caused that issue.
I see people say to check the fuses, but is it a case of if the passenger side window is working it won’t be the fuse as that one should not work too, if it was the fuse?
I’ve been doing some research and people have said to check the wiring between the door, to the car. I tried to pull off the rubber grommet where the wiring harness plugs into the car, but I had difficulty getting the back of it off. I got the 2 front clips out but couldn’t get the back clips out, I’m guessing there will be 2 at the back too? I could stretch the front out a bit to have a peek inside and from what I could see, the wires looked okay. I took the door card just to check the part number of the Window Motor which is 8P0959801K. I saw that sometimes there is a issue with the Door Switch, where the window button are, how would I be able to tell if there is an issue with those?
The other issue is related to the car's central locking, I can lock the car by pressing the key fob. When pressing the key fob to unlock the car. It does the double light flash but I have to use my key in the door to open the drivers door. The passenger side door I have to open from the inside, these issues have been going on for a while, but I’ve lived with them but ideally I could get these sorted out as well. But the main issue Iwant to deal with is getting my drivers window to wind down for when using tickets machines, etc.
I did VCDS scan of my car and had quite a few errors. The ones I believe related to these issues are below.
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0959 801 K HW: 8P0 959 801 K
Component:Tuer-SG H03 0060
Coding: 0000564
Shop #: WSC 06314000 00000
3 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
012 -Electrical Fault in Circuit - Intermittent
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 -Implausible Signal
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0959 802 K HW: 8P0 959 802 K
Coding: 0000564
VCID:4487A09707FDF8B1A7-8010
4 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00944 - Heated Exterior Mirror; Passenger Side (Z5)
01331 - Door Control Module; Driver Side (J386)
Re: Audi A3 8P Drivers window not winding down and central locking issues.
Every component in driver's door has fault - strong possibility that You have read correctly - look for wiring issue in the loom between the door and car.
Sent from my Pixel 6a using Tapatalk
Thanks, I'll have another look later. When trying to pull the rubber grommet out I couldn't get the back clips out. Theres not much space, to push clips at the back with fingers.
I tried to take a video of what I could see, here is a screen grab of that. I'm on mobile phone at the moment and don't see an upload option. I'll upload an image when I get to desktop.
1 Attachment(s)
This is what I could see, when pulling the rubber grommet away from the front. Like I mentioned I couldn't seem to get the back clips off, felt like I would break it just pulling it with out pressing the "tabs" at the back? Any tips for getting it fully off? and is this where the issue is likely to be?
Attachment 39337
The wires tend to break past where you can see in your pic. The two clips at the back are the same as the front - you do need to get your fingers behind and press them in to remove, it's tricky but doable. Maybe try putting the front back in place, then removing the back clips first might help.
1 Attachment(s)
Thanks for the tips, I managed to get it off, doing as you said. At least 3 wires were broken. Not sure if I might have broke one wire further as the key fob is not locking my door afterwards. I can manually lock the door though.
Does this mean I need a wiring loom or repair kit? The broken wires that I could see were the brown one, red and green one, black one, and then a couple of others had little breaks in them
Attachment 39338
Called Audi, they said that there's two options it could be after first saying that they don't make them anymore, this was after he said he will check if there were repair wires, so maybe he was talking about those. Refused to give out part numbers for the 2 options that he mentioned.
First option. £197. Connects to the window regulator, switches and mirror. (he said attaches to the door card)
Second option. £197. Attaches to window motor and goes to the car body (mentioned that it has a rubber grommet, that I mentioned when trying to describe where it was, what it looked like)
I've just spliced in new wire lengths for the broken (and cracked, soon to be broken) wires. A bit fiddly as its not always easy to get enough 'good' wire to splice to in the available space. However, it has worked. On another car I bought a new plug with flying leads from ebay (maybe around £20?). Take the door card off, pull the plug and part of harness through from the inside of the door and then it's relatively easy to splice in every wire before threading back through the door and reconnecting. The proper way would of course be to replace the whole wiring loom (your second option).
Thanks for the advice.
I managed to change the loom with one I got from ebay today. But I might have to mess with it again tomorrow as it was getting too dark outside. The only issue, I had is the little black clip that goes into the door near the speakers was facing the wrong way, so I couldn't clip it in and the metal clip that slides onto the inside of the door below that area wouldn't clip on.
Originally, After I threaded the cable through the door, I noticed the main plug was upside down, but I could turn it to get it upright. I hope I don't have to take the whole cable out again. I don't want to risk damaging any of the wires on the connector to the car body, as when I took the old one off, I pulled it by the wires as it was getting replaced.
Okay, here's a little update. I got the wire clip on, I put the door card back on, turned on the car and I have nothing working on the drivers side switch(window wind up/ mirror movement) before it was just the drivers side window not moving.
I dug out my laptop with VCDS and it said it had an hour battery left, thought okay I'll probably get a scan, started the scan near the end it cut out but got the initial results without clearing. I have the laptop on charge now, I'll later clear and rescan. Could it be a fuse?
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 245
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008700068
Coding: 11AC2F07A0141380EF00001C4F00000000084E056401000300 2000000000
Shop #: WSC 06314 000 08192
VCID: 489FB4A73BD5DCD14B-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 66
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:00
Freeze Frame:
OFF
Voltage: 12.35 V
OFF
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K087150898
Coding: ED801F061002020101
Shop #: WSC 06314 000 00000
VCID: 3561CD535C27513920-8060
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 8
Mileage: 144759 km
Time Indication: 0
Date: 2024.01.20
Time: 19:33:19
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 30
Reset counter: 48
Mileage: 144952 km
Time Indication: 0
Date: 2024.02.03
Time: 17:26:05
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
VCID: 4385A38B02F3FF899E-8016
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 4487A09707FDF8B1A7-8010
3 Faults Found:
008 - Implausible Signal - Intermittent
012 - Electrical Fault in Circuit
Took the door card back off and made sure the connectors were seated properly. Now only the drivers window works from the door switch. Both the mirrors and passenger side are not responding to presses on the switch controls, they worked prior to swapping the loom. Also the passenger side switch can control the passenger side window up and down.
I need to look for one of those circuit testers I've got stored away some where to try and check the fuses.
Any other suggestions?
Has the eBay loom the same PN as the old loom in the car?
Quote:
Originally Posted by
Sibmets
Hi, I used the part number on the original loom to order the current loom. It has the part number on the loom sticker in a slightly different place than the original sticker, but I assume it's the same part.
So it seem the drivers window working, going down/up is intermittent. Tuesday, I think, the drivers window wasn't winding down on the way to work, when leaving work it was working. Yesterday and today it's not winding down.
Here's a few pics of the part numbers. First is the original one. The second one is the new part.https://uploads.tapatalk-cdn.com/202...95aacea635.jpghttps://uploads.tapatalk-cdn.com/202...2f1d61dc7b.jpg
Sent from my SM-S911B using Tapatalk
Also, one other thing on the Digital Instrument Display (DIS, I think is the name) behind the steering wheel, it shows that my drivers door is open and remains like that whilst the car is on. I haven't tested the fuses yet as I've been unable to find my multi meter, which I've stored away.
Could be that either the wiring from door sills side or the actual driver door window module itself could be faulty. I'd check the wiring (don't know how much there's access to do that) or get a window module from used part sellers (or maybe temp swap from other side by just plugging in it and reading faults)
Sibmets
I took a video of the loom before putting it into the door. I'll post a couple of screenshots from the video. Probably what you can see in these screenshots is probably a bit more than if I unconnect the connector that attaches to the car body.
Yeah, I could try swapping the window module from the other side, but I will likely need to wait until the weekend and then find a free space to do the work.
Is there a way to test the window module with the VCDS with the door card off? Just thinking when my door card was off and I couldn't press the door switches (windows,mirror switches).
I still have the old wiring loom, I was wondering if it might be worth trying to repair that wiring loom? It had 3-4 broken cables. Anyway, that may be for another day [emoji38] I'm just thinking of repairing it, threading it through, and it falling apart halfway through [emoji20] [emoji38] https://uploads.tapatalk-cdn.com/202...2ee1b6bc3b.jpghttps://uploads.tapatalk-cdn.com/202...8e29445c30.jpghttps://uploads.tapatalk-cdn.com/202...ff8cde6f16.jpg
I picked up a cheap multimeter as it was the only one they had left in Halfords. I wanted to check the fuses by the steering wheel doing a continuity test, unfortunately it doesn't have the "beep" function on a complete fuse. I was wondering, does it matter what side you put the positive/negative probes ?
On Continuity test I know 1 means there is no circuit / likely fuse is blown. I went through all the fuses by the door, a couple came up with 0.00 and I was wondering if that meant anything, a few I swapped the probes around and then got another reading. I'm new to this, but I think any reading other than 0 is fine?
Do a voltage check across the pins for the red/green and brown wires, should be permanent 12v.
Cheers, I'll give that a try tomorrow. A question, might seem silly but where do I put the negative(black) connector from the multi meter? The positive (red one) I assume makes contact with the wire as it goes into the plug/connector. Think I read the negative is usually grounded, where would I ground it too?
Red lead to the red/green and black lead to the brown or any good earth
Hi Crasher, there isn't any space to check whilst it is plugged into the door connector as the space is too tight. Not sure if there's some sort of adapter to get into tight spots.
In the meantime I bought a replacement window motor hoping that, that might resolve the issues that I'm having. I've replaced the window motor today and the issues are still the same. Are there any trouble shooting steps you would suggest or to check with the wiring loom.
Maybe I could check the socket that the loom plugs into? If so, how would I go about that.
I messaged the ebay seller to ask if they tested the loom beforehand, this was their response
"Yes this was definitely working when we removed it off the car hence we listed it for sale. And we removed this with great care as I know how fragile these are.
90% of these we remove are damaged hence it was on eBay for less than 3 hours and it sold. So it was definitely working when we removed it."
I use needle probes that make a tiny hole in the insulation but watch your fingers :eek:
I haven't done much since the last post. I was going to remove the loom but then thought I haven't done a VCDS scan on the car since installing the new loom. Anyone know where I could get needle probes for a multimeter on the high street?
Are there any companies or people who repair the wiring looms? as my old one is out of the car and has 4 broken wires if I recall correctly. Are there certain repair wires needed? I wouldn't mind paying someone to sort out the wires.
Another note, previously, before this issue I was getting an error with the door lock module for the drivers door, where the drivers door wouldn't lock with the central locking, but that I could lock with the key. Anyhow, here's a scan I took today. I remove certain parts as I'm not sure if the whole data is safe to share vin / vcid?
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 16426012492400FB680C06EB921B00813900
Shop #: WSC 46093 001 1048576
1 Fault Found:
01169 - Door Contact Switch Driver Side (F2)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 36
Reset counter: 39
Mileage: 144962 km
Time Indication: 0
Date: 2024.02.05
Time: 08:35:32
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 147
Count: 52270
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH09 0100
Revision: 000397 Serial number:
Shop #: WSC 00000 000 00000
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 35
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 224
Reset counter: 39
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 20:57:00
Freeze Frame:
ON
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 193
Reset counter: 39
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 20:59:20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 142
Reset counter: 79
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 21:08:53
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 3
Reset counter: 79
Mileage: 145076 km
Time Indication: 0
Date: 2024.02.12
Time: 15:34:44
Cannot be reached
1 Fault Found:
Coding: 0000564
4 Faults Found:
I'm back, and still have the same problem :( lol
As the weather has started to get better I decided to attempt to repair my old "door wiring loom". I ordered previously a repair kit from eBay, that had the main connector (the wiring harness end that plugs into the car) and wires with crimp terminals to plug into the main connector. The kit came with "butt connectors" that could be heated up and had glue inside.
I replaced the wiring harness, put everything back together and.... I got the same result! Nothing working from the driver door switch. Quite disheartening as it took a while to do.
I never did end up getting the needle nose probes suggested to test the green/red and the brown cables in the harness. So guess I should order a pair, also I may look out for a multimeter that "beeps" lol if you guys have any recommendations for one, I'm open to suggestions.
The wiring loom I took out, that I bought from eBay to replace my original one doesn't appear to have any damaged cables, for as far as I can pull the rubber grommet/cover down whilst out of the door.
Previously I replaced the driver door module with a second hand unit. I also checked the fuses by the drivers door which seemed okay from memory.
What are other likely things that it could be? I think I'm going to check the fuses again, get the needle probes to check the power of the red/yellow and brown cables. I was thinking it could possibly be the plug in the car that the main wiring loom connector goes into or possibly the actual door switch (that controls the windows/mirrors) Any of these I can rule out based on the information provided?
Any other suggestions welcome. Thanks.
Are the codes still the same?
I'm not too sure, think I'll need to dig out my laptop and VCDS to give the car a scan.
Here's a new scan, taken today of what looks like the issue parts. I've also ordered a pair of needle probes from Amazon that are due to arrive later today. I didn't clear the codes, so I'll do that and scan again.
Saturday,08,June,2024,13:20:23:26151
VCDS Version: 24.5.0.0 (x64)
Data version:
Ross-Tech: Home
Repair Order: 2024 08 June Scan1
Chassis Type: 8P-AU35 (1K0)
56-Radio -- Status: Malfunction 0010
Revision: 00H45001
VCID: -8054
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 238
Reset counter: 242
Mileage: 144962 km
Time Indication: 0
Date: 2024.02.05
Time: 08:35:32
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 147
Count: 52270
Count: 0
Count: 0
Count: 0
Revision: 000397 Serial number: 8P0820043BG
VCID: -8026
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 71
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
VCID: 801C
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 202
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 20:57:00
Freeze Frame:
ON
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
VCID: -8060
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 194
Mileage: 144960 km
Time Indication: 0
Date: 2024.02.04
Time: 20:59:20
Cannot be reached
VCID: 4385A38B02F3FF8E1E-8016
2 Faults Found:
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Coding: 0000564
VCID: -8010
4 Faults Found:
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8938668
Coding: 0330211
VCID: 806A
2 Faults Found:
00871 - Bass Speaker Front Right (R23)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 242
Mileage: 147302 km
Time Indication: 0
Date: 2024.04.30
Time: 18:14:58
00857 - CD Changer Unit (R41)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 8
Reset counter: 223
Mileage: 147231 km
Time Indication: 0
Date: 2024.04.26
Time: 17:00:27
End-------------------------(Elapsed Time: 02:14)--------------------------
Here's a scan after clearing the codes.
Revision: 00H45001
VCID: -8054
No fault code found.
VCID: -8026
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 71
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
VCID: 801C
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 148058 km
Time Indication: 0
Date: 2024.06.08
Time: 14:00:00
Freeze Frame:
ON
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000 Dataset Number: 8P0909602L 0001
Coding: 303142413039303030384A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: -801C
Crash sensor for side airbag: driver side:
Serial number: 34928RB400003E9B452U
Front Passenger's Side Airbag Crash Sensor:
Serial number: 35028RB400003EB0497M
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400003E9A961R
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400003EB0568N
Crash sensor for front airbag: driver side:
Serial number: 35547RB400003E5BE9C5
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400003E5C0E3W
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0012112
VCID: 4189A98318EFED9E0C-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
VCID: -8060
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 148058 km
Time Indication: 0
Date: 2024.06.08
Time: 14:01:11
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 8P0 920 982 E HW: 8P0 920 982 E
Component: KOMBIINSTR. VDO H15 0830
Revision: D0H15005 Serial number: AUX7Z0H6FNI0I8
VCID: -806E
Cannot be reached
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 234 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 807E
VCID: 8016
1 Fault Found:
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850212944
VCID: -8060
Coding: 0000564
VCID: -8010
2 Faults Found:
Coding: 0330211
VCID: 806A
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 202
Mileage: 148058 km
Time Indication: 0
Date: 2024.06.08
Time: 14:05:01
End-------------------------(Elapsed Time: 01:57)--------------------------
Checked all the fuses by the steering wheel and under the bonnet. They all had readings, so, it doesn't look like one of the fuses. I see the door control module mentioned a few times in the scan. Is there any way to test the windows, mirrors with the door card off? I read some people got lucky unconnecting / reconnecting the connector.
The door control module I have in the door at the moment I got second hand from a part place. I still have the old one, not sure if I replaced it before or after I got the second hand wiring loom.
I swapped the door control module back over with the old one today. Looks like it's still the same. Here's a scan after clearing the codes. The instrument one has been there for before this issue but I removed as probably unrelated to the issue.
Sunday,09,June,2024,14:03:31:26151
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1803
Revision: 04843012 Serial number: 00000807020019
Coding: 0000020
VCID: 8046
Revision: 00H45001
VCID: -8054
VCID: -8026
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 23
Reset counter: 71
Mileage: 144789 km
Time Indication: 0
Date: 2024.01.23
Time: 17:09:14
Freeze Frame:
ON
VCID: 801C
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 202
Mileage: 148058 km
Time Indication: 0
Date: 2024.06.09
Time: 13:33:00
Freeze Frame:
ON
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
VCID: -801C
Coding: 0012112
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Revision: D0H15005 Serial number: 2246H005001956
Coding: 0000428
Shop #: WSC 11242 000 1048576
VCID: -806E
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 120878 km
Time Indication: 0
Date: 2017.11.23
Time: 00:34:23
VCID: -8060
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 202
Mileage: 148058 km
Time Indication: 0
Date: 2024.06.09
Time: 13:40:37
VCID: -806E
Cannot be reached
Revision: 00H15000
VCID: 807E
VCID: 8016
1 Fault Found:
VCID: -8060
Coding: 0000564
VCID: -8010
2 Faults Found:
Coding: 0330211
VCID: 806A
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 202
Mileage: 148058 km
Time Indication: 0
Date: 2024.06.09
Time: 13:59:15
End-------------------------(Elapsed Time: 02:17)--------------------------
Here's a picture of my wiring loom repair before I added electrical tape to it. Also, im just wondering what the connector in the third picture is for? As that one doesn't come out with the wiring loom.https://uploads.tapatalk-cdn.com/202...fe4cb8ec61.jpghttps://uploads.tapatalk-cdn.com/202...8febca7faa.jpghttps://uploads.tapatalk-cdn.com/202...95eed12f56.jpg
I think I found the problem, the wiring loom connector wasn't pushed all the way in. But I noticed that it wasn't clipping in to place. I used the old wiring loom connector that I cut from my old one during the repair, that wouldn't "click" into place either.
When I pushed the connections together and put the door card back on, closed the door. The windows and mirrors worked from the drivers side switch. I moved my car, when I next tried again, it wasn't working, probably the connector in the door loom has come out of the socket again. Looking at the socket, it looks like some of the bottom part of the socket might be broken, it's hard to see. My gues to what caused it could be that I didn't get the connector in properly behind the rubber grommet and maybe the force of the door closing on it chipped the bottom part? as the socket was initially secure when I first started all this and I didn't notice anything break during the other times I've been attempting this fix.
So I guess now I need to secure this socket some how. Anybody have any suggestions for semi temp solutions? or will I need a new socket?
If it is the one in the picture then I would change it, the part number is on it. You will need the specific terminal tool, I get the plug number to be 1K0 972 928 which costs £12.42 but you must use the correct primary locking tool VAS 1978/35-23, for the secondary one a thin blade screwdriver will suffice. Damage the pins and you are in a world of hurt. This doesn't seem to be available in the universal sets
Cheers, I've attached a few pictures of the connector. Not much space, so the pictures are quite close up, but I think the bottom part looks broken.
https://uploads.tapatalk-cdn.com/202...f63ca73516.jpghttps://uploads.tapatalk-cdn.com/202...50edbe7ca4.jpghttps://uploads.tapatalk-cdn.com/202...ff3e4985fc.jpg
The A pillar connector, nasty! That is a lot of delicate work, contact housing 8E0 972 701 you must use the correct tools 1978/18 and 35-24
https://i.ebayimg.com/images/g/NhAAA...ZUZ/s-l400.jpg
https://youtu.be/19WZo51BDto
Looking at the A Pillar connector in the picture you posted, I'm wondering if it is broken. I'll probably have another look at it tomorrow at some stage. Is there any reason other than it being broken that it might not "click" back in? Could it have been pushed back into the car body, or perhaps I haven't pushed it back hard enough. I haven't messed with the pink tab at the top that I recall.
They can be a real PITA due to the tight space.
