Re: Sporadical P0135 code
have you cleared the STORED & PENDING codes ?
What was the make of the new sensor ?
Hi Niall,
Yes, I cleared all kind of codes (did it with OBDII readers and VAG-COM and VCDS), several times.
The sensor is an NTK sensor (LZA11-V4 or NTK 1842) and these sites are telling me that it is compatible:
1 X NGK LAMBDA SENSOR LZA11-V4 1842
LZA11-V4 | NGK Oxygen Sensor 1842 | Lambda Probe
NGK Lambda Sensor (1842) buy cheap online
And this converter says the same as well:
http://www.oxygensensor-crossreferen...t/ntk/LZA11-V4
Well, I would say that I would replace the sensor.
If you have kept the receipt ,then just exchange it. Plenty sensors break or are broken when new, whilst its a pain ; its worth remembering when you fir them you tend to think it must be something else.
As its sporadic,its entirely up to you if you can put up with it or not
Thank you for the idea and advice, much appreciate it.
Anyone else with any ideas before I change the AFR sensor that ran only ~20.000km and one year old only?
Crasher? Any advice on what else to check? Wiring diagram? Fuel pump relay can be related?
Something is wrong because according to the VAG workshop system the AZD engine cannot generate
16519 (P0135) Bank 1 Senor 1(G39) - Heater circuit malfunction
as it is not on the list of possible codes although that could be wrong as the matching code for B1S2 P0141 is listed.
Check the brown and blue/yellow wires at the six pin plug on the gearbox for breaks or corrosion to the pins.
Thank you, Crasher, for the quick answer!
The connector and all pins are free of corrosion.
What I found is that probably the naming is weird to me:
Z19 - Lambda probe heater
Z29 - Lambda probe 1 heater, downstream of catalytic converter
Why it is referring to Z29 (downstream) sensor as "1"?
P0135 means B1S1 but according to the naming it is probably
not for the upstream but for the downstream sensors? :S
G39 is the pre cat sensor, B1S1 and Z19 is the heater for this, Z29 is the heater for G130 which is B1S2, the post cat sensor.
B1 = Bank 1 (but it has only 1 bank!)
S1 = Sensor 1
S2 = Sensor 2
Check for battery voltage across pins T6q/1 and T6q/2 with the engine running
NGK sensors are referred to by the technical components operations brand name NTK. The probe was originally VAG part number 036 906 262 E which changed to 036 906 262 J and this is an NTK LZA11-V4 or the quick reference number 1842 so what you have fitted is technically correct. However, a few years ago I did the same thing on a Passat and in the end found that the NTK’s heater resistance was way off what the original Bosch one was and the ECU just would not accept it, a Bosch part cured the problem so you could have a similar problem. VW do not provide a specification for the resistance of Z19.
http://i222.photobucket.com/albums/d...psaxokuyw1.jpg
Yes, I saw the thread of the Passat and I will check the voltage between T6q/1 and T6q/2 with the engine running tomorrow.
Can you do me a favor? Where exactly E7 is and how is it look like?
According to the diagram - if I'm not mistaken - E7 is a kind of junction point and not only one thing is connected to it but more - the fuel pump relay, the pre- and postcatalyst lambda sensor and the activated charcoal filter solenoid and fuse #43. These electrical loads are connected parallelly as I see and if I measure 9.85V on the Z19 then I must read the same voltage on the others' blue/yellow cables as well compared to the battery negative connection - if the quality of the cables and connections are the same to all endpoint, right?
The positive wire "entry point" for these electrical loads is the fuse so I must check the voltage on the fuse as well I think to check is there any voltage drop.. But how E7 and fuse #43 is connected to the battery?
So, I measured the voltages with running, warm engine:
Fuse #43 to the chassis ground (both ends): 12.15V
B1S1 Z19 heater circuit - between brown and blue/yellow wires (T6/q1 and q2): 12.14V
I started Torque Pro and checked the Mode $6 monitors, everything is green, completed.
Then checked the measured value reports and found something odd:
Test report:
TID:$01 CID:$06
- Rich to Lean sensor threshold voltage(constant)
Max: 5,000
Test result value: 3,333
PASS
TID:$02 CID:$0e
- Lean to Rich sensor threshold voltage(constant)
Max: 1,000
Test result value: 454
PASS
TID:$02 CID:$10
Max: 510
PASS
TID:$02 CID:$11
Min: 390
PASS
TID:$02 CID:$12
Max: 956
Test result value: 761
PASS
TID:$02 CID:$14
Min: 700
Test result value: 888
PASS
TID:$02 CID:$1f
Min: 100
Test result value: 455
PASS
TID:$05 CID:$0e
- Rich to Lean sensor switch time(calculated)
Max: 200
Test result value: 9,640
FAIL
TID:$06 CID:$05
- Lean to Rich sensor switch time(calculated)
Max: 4,300
Test result value: 3,828
PASS
TID:$06 CID:$06
Min: 3,400
PASS
TID:$06 CID:$07
Max: 1,300
Test result value: 456
PASS
TID:$06 CID:$09
Max: 935
Test result value: 767
PASS
TID:$06 CID:$0a
Min: 650
PASS
As you can see TID:$05 CID:$0e has failed and I tried to reset it and let it measured again by the ECU several times but always fails. The most interesting thing in this is: the OBDII readyness for O2 sensor is always complete/pass. According to the Torque Pro tests this test (TID:$05 CID:$0e) is the calculated rich to Lean sensor switch time - but this is an AFR sensor, not a simple, 4 wire O2, so this is confusing to me as well. Is there any documentation of the TIDs and CIDs? Or it is something secret? How come Mode 6 test 5 component 0x0E (decimal 14) fails but the readyness of the O2 is always green/pass? :\
The connection E7 is just a welded point or crimp terminal "somewhere" in the harness but from your figures it is OK. I think the NTK sensor heater circuit is not drawing the current the ECU would expect. Do you have the old sensor? If the heater circuit is intact you could check the resistances against each other, I don't know what that one should be.
Quote:
Sent from my SM-A300FU using Tapatalk
