Hi everyone! Somebody know where is thermostat in my car?
Printable View
I do apologise! Audi A6 C6 2.0 TDI 170bhp, march 2011 engine CAHA
I don't think it will make your heater work better.
I asked for it because yesterday driving 15 miles usually temperature reach 90 but it was just 80 and when parked on idle when down to 75,but heater I set on 20.5! I know! Little warn inside:D
I thought that something happened with thermostat.Today I set heater on 18 and was all the time 90. Is yhe way it should be?
Please note that there is one more thermostat, I have similar problem with my 2.0 TDIe 100kw. I have ordered this small one to see if it will help. I will let you know.
Part number is 1K0 121 113 A, this is small thermostat which is on return hose from EGR cooler to 4/2 way valve with main thermostat and going directly to engine.
I have notice that when engine does not have any load coolant temp is going down.
We will see as soon as I remove this small thermostat is it good or not.
I have found plenty BMW with this problem on site.
Your heater is like another rad. if you are taking heat out of it your engine temp will go down.
The engine doesn't make the heat on idle that it makes when driving, + it was cold yesterday.
Maybe is not the problem, maybe it is like that during colder weather (as many forum members suggested). I have notice that as soon as ambient temperature is around 10 deg C or above, everything is ok and coolant temperature is steady on 90. Only that I am new to the car and my previous A4 did not have such behavior.
Anyhow, I have ordered this small (EGR) thermostat.
I will let you know what happen as soon as I replace it.
Novak
Hey guys,
I know this is an old topic, but I have a similar issue on my A6 C6 2011, 2.0 CAHA - cooling liquid not getting to temperature. Last year it was OK, but starting this winter I've had these issues. My main problem now is that I cannot seem to find any of the 2 thermostats. Any pics are more than welcome, or Elsa screens, anything that would get me on the right track.
Does this help ? VW/AUDI 2.0TDI Main engine thermostat change - YouTube or this
If you have a DSG box, it's usually the DSG cooler thermostat that fails.
This causes the coolant to get overcooled leading to low coolant temperature, poor heater & higher fuel consumption.
I have seen that, but it does not look like what I have. I managed to get a picture of what's there:
Attachment 36935
By the looks of it, I need the thermostat with part number 03L121111AD. BUT, I know that there are 2 thermostats, so... where is the second one? I spoke to the guy from the parts store, and he told be (by phone) that by the VIN number of the car, there IS another thermostat, that is somehow very close to the water pump, on the engine block, but his picture shows just like this:
Attachment 36936
So, if this is the case, does it mean that on top of the thermostat in the second picture, I have and need to replace the thermostat from the 1st picture? Is it possible that there are 2 thermostats in the same engine block hole?
No, it's a manual gearbox.
You have this other type of housing fitted to your car.
The Thermostat is the same 03L 121 113 A for both types of housing.
Attachment 36984
