Re: DAB intermittant muting
So I have a C7 A6 (2011 MMI firmware 770) with DAB and a blackvue front & rear cam. DR650GW 2CH, I also have DAB.
I fit to the interlink between 2 cameras a ferrite core & to the power line feeding the main camera from the driver side fuse box.
No DAB problems. Ferrite cores suppress electronic noise that can upset DAB.
http://www.maplin.co.uk/p/ferrite-clip-on-hem3012-n89ab
HEM3012 (2.5mm hole) for single core.
Code: N89AB
Some HD video cams can cause problems for DAB as they can interfere on high frequencies.
Also DAB antennae connection if loose would be a problem when VIDEO CAM powered off, so do a test, KILL the power to the cam for a day or two.
Great - many thanks. I have one already but thanks again for the Maplin link.
I had a similar problem and it was the 12v to 5v adapter I was using to power my dash cam that was to blame. Switched over to a socket (running off a fuse tap) and this adapter:
VeetopĀ® Dual USB High Speed (MFI Certified) Car Charger UPGRADE 3.4Amp 15.5W - 2.4A & 1.0A, Smart charging for all iPhones (5S, 5C, 5, 4S, 3GS, 3G),iPad Air, iPad Mini, Apple iOS7, iPod,iPod Touch, Samsung Galaxy S5/S4/S3/Note 2/3, Nexus, Sony, Nokia, HTC, LG, Motorora,Huawei, Lenovo, ZTE, GPS,Smartphones & Tablets (Black/Silver): Amazon.co.uk: Electronics
12v Female Car Cigar Cigarette Lighter Socket Plug Connector High Quality 2M 5A: Amazon.co.uk: Car & Motorbike
Great reception now :fing02:
Another great reply - many thanks.
If you go into the hidden green menu in the MMI, there's a way to show the radio signal strength. Then you can switch things off & on and see what happens.
Also, if you search the forums, there was someone who had a bad heated rear windscreen which caused radio problems and needed to be replaced.
All good points, the one about a 12v DC to 5 v DC adaptor is especially true these days with cheap versions of electronic power droppers.
The Cam I use runs 12 v DC direct via a fuse tap & timed regulator "Power magic".
Blackvue Accessories : Power Magic Pro - Power Controller
Google Fuse tap
Can I ask if there is any update on this issue? I plan on buying a Blackvue 650 front and rear camera kit with the Power Magic suply but I am wary of the DAB issue.
2 Attachment(s)
Quote:
Originally Posted by
wildbore
Hello Wildbore,
I've been running my Blackvue 650 dual camera kit for 4 months now and no issue with DAB.
Like I said earlier I have a ferrite core on the rear camera end about 4" (inches) away from the cam on that line & the another on the other end at the front, same line running to the front camera.
I have a 64Gb micro SD card in and record continuous, I use the Blackvue power magic pro box (power controller) that switches off the blackvue after 12 hours of no ignition.
I've never had the battery go flat, I've had no DAB issue.
The only issue I've had is a corrupt micro SD card which I had to reformat in the main PC, this is a common fault of continuous record , rerecord looping systems.
The card runs none stop for about 3 months before I had the first corrupt card.
What I've done now is to format & prep a second card which I keep in the car if the main one corrupts, then I switch off (pull the power lead out) let the blackvue shut down, then remove one microSD and push-in the spare, power up and off it goes again. I carry the spare microSD card because when the Blackvue fails to read the card, it says a continuous message, telling you to remove the card, can be very irritating...
Anyway, it's works flawlessly, recordings are clear, I have a 2011 A6 saloon with rear window tinted (privacy glass) and both front and rear cams do a grand job.
The camera runs in parking mode when the ignition is off and records any movement event.
you'll love it.
You can't see the small ferrite cores as they are behind the headliner front & back
Attachment 28260
Attachment 28261
Yep i agree with all of the above, have exactly the same setup and once you attach the ferrite cores to the camera leads the DAB problem is solved....
Sent from my iPhone 6 using Tapatalk Pro
Thank you both for the replies - especially Noscream for the very in-depth response. My rear view mirror mount is significantly chunkier than the one in the photo so that could be a bit tricky to work around, but I am definitely going to order one of these today and see how I get on.
mckee25
shame that this £300 camera doesn't 'work out of the box' especially when this is a known issue for a while now
