hi all
can anyone shed any light on why my exhaust fumes are so bad, its been like this about a year now, theres no smoke and no lights on the dash, i have looked at the lamba readings on mb075 using vcds and it shows 27%. is it possible my lamba sensor is knackered and the dpf is blocked?
if you put your face in front of the exhaust it makes your eyes sting and water, and you can smell the fumes if stopped at the lights with window down.
its the 170 bmr engine
could it be turbo related, i ask this as i had a failed oil pump last year and never replaced the turbo as it seemed ok, the car still drives ok, i replaced the tandem pump a few months ago due to finding the fuel in the filter housing to be black, i have a feeling that the fuel is black again as i am getting the same misfire when i floor it again, which was the reason for checking the fuel in the first place, so i have either got another knackered tandem pump or the injector seals have gone.
hope this makes sense and that someone can put all this together and make a diagnosis
many thanks
