Audi A6 C6 2008 Starting , AC and central Lock problem
Hello Mates ,
I am new in this Forum and I would like to thank all moderator to be accepted here .
Please excuse me as I am new in this forum for my problem description and also I am new as an Audi owner
I m a new owner of an an A6 C6 2.4 PETROL , BDW engine code Multitronic 7g GEARBOX , 2008
I have some issue with my car as following :
1-/ Key can not unlock the car doors : I have to open manually from the driver door :
VCDS diag
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 227
2-/ Starter problem : car wont start only after several attempts and I hear a noise from the starter side : it s coming from the starter head which I think it need replacement , so it s a mechanical problem
VCDS diag
[05] - Access/Start Authorization
01176- Key 004 - No Signal/Communication - Intermittent
Fault Priority: 2
Fault Frequency: 225
Reset counter: 227
00446 - Function Limitation due to Under-Voltage: Lower Limit Exceeded
Fault Priority: 2
Fault Frequency: 2
Reset counter: 207
and in the Engine Blocks I think I have related issue
[01] -Engine Electronics
006450 Data bus powertrain , implausible message from immobilizer
P1932 - 008 - intermittent
Fault Priority: 2
Fault Frequency: 1
Reset counter: 21
3-/ Battery error :
3-/ Address 61: Battery Regul. Labels
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 9
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
02276 - Quiescent Current Stage 5
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 4
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
5-/ AC : not working
despite the blower blowing and I read meas blocks found pressure 7.6 Bar when engine idling , blower working , but compressor not coupling !
VCDS DIAG : NO ERROR .
Please help .
with kind regards
Adel75
Re: Audi A6 C6 2008 Starting , AC and central Lock problem
The battery is flat and/or not charging which is a common issue on these when the signal wire from the alternator to the battery controller fails.
Quote:
Hello Mate ,
Thank u for the reply , I guessed that , Battery changed with a new Varta one 100AH , nothing changed still all the 3 issue sitted up : key locking not working , starter also difficult , AC not working
any help pls , which part is the cause , how can I track all these issues
regards
Adel75
What codes are coming back after a full clear, drive and re-read?
Hi sorry for my late reply I was away from the car
work done Boss : I have clear the faults drove the car and here my issue let s solve it one by one
1-/ difficult starting :
the sound coming from the starter I will attack this week , I will put new starter because I take a look on the starter and it seems to be out ! sound grezzzzz and only starting after several time even after putting the new battery
Diag
Adresse 01: Moteur (BDW) Labels: 06E-910-552-BDW.clb
No. pièce Log: 4F2 910 552 Mat: 4F0 907 552 F
Pièce: 2.4l V6 MPI 0010
Révision: --H20--- No. de série:
Codage: 0105001002070160
No. Atelier: WSC 02325 785 00200
VCID: 62D7CAE3A7BDAA2021-8036
1 Fault Found:
009523 - Ignition Switch; Run/Start Position Circuit
P2533 - 006 - Open or Short to Ground
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Address 05: Acc/Start Auth
2 Fault Found:
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
et 01176- Key 004 - No Signal/Communication - Intermittent
Fault Priority: 2
Reset counter: 227
wich is going and coming after erasing
what s responsible of that ?
I still also have my remote not able to open the door , I still open the door mechanically !!!
please help
with kind regards
Adel
At the moment you need a new ignition switch, a fairly common problem and easy to deal with.
HiCrasher
Thank u for the quick reply .
u mean this one :
audi a6 c6 ignition switch replacementþ - ÈÍË Googleþ
does it need programming or coding , I am going to buy a used one , I have VCDS
please help and advise
regards
Adel
Yes, the unit is not keyed to the car, I assume they didn't feel it was necessary so any key of the correct type will turn the switch, the anti theft function is provided by the chip in the key.
Thank u so much , I will buy a used one and let u know .
Crasher by the way do u have wirig diagram to the head light modul Central Electro 4F0 910 279 K
I bought the car with a retrofit DRL Led light headlight xenon same like this one :
AUDI A6 C6 HEADLIGHT LEDþ - ÈÍË Googleþ
and when I have done some search I found that Central Electro 4F0 910 279 K is managing Led light facelift , my issue are :
Led light are not working in both side , my car is 2007 model ! please help
with kind regards
Adel
It won't be wiring, get rid of the HID system and recode the central electrics to remove hot bulb monitoring.
