Re: Q7 (4M) Coding - Last Updated 22/9/2016
Quote:
Originally Posted by
andyhud007
Can you do a coding and adaption map export for me?
Not sure how to do that with OBD11, or if it can even be done. But I'll look next time I have it out.
In the mean time, I turned on Module 46/Control Comfort Sys > Adaptation > Central Locking Sys: beep at opening and now I have it beeping on unlock.
BUT... it no longer beeps or flashes on lock. HOWEVER, I was getting a battery low warning from the Q7. So maybe that's the problem. Will have to wait til the car is charged and see what's going on.
Andy, do you see anything in Sunroof module that would prevent the electrically actuated sunroof shade from opening when you use comfort opening to open all window with key fob?
Re: Q7 (4M) Coding - Last Updated 6/8/2016
I tried changing shut_off_foglight_on_high_beam_or_flash in 09/Central Electric from active to not active. Unfortunately, it looks like the front fog lights still go off when high beams go on.
Boy do I feel stupid. I was running the battery down while doing all these mods and so I opened the hood to hook up a charger. With the hood open, the car is not fully locked, so of course it made no sound and flashed no lights, even though you could hear the door locks engage. :Blush2:
Turning On Module 46 > Adaptation > central locking system > beep at opening DID enable the chirp on unlock. So I now have single chirp plus flash for unlock and double chirp and flash for lock, just as I wanted.
Thanks for your help!!
BTW, I also change Mod46 > Adaptation > sounder_settings > beep time from 10ms to 60ms and sounder sound from discontinuous to frequency modulated, which together seems to have increased the perceived volume of the chirps (by a little).
1 Attachment(s)
Here's a complete summary of everything I've done so far...
Attachment 31627
RickOb
Thanks Rick, liking the look of increasing the speed for park assist. Just to confirm, can you also turn it on at that increased speed?
On my commute I drive up to a blind junction and it annoys me I have to almost stop before it will turn on the wide angle front camera !
srbsq7
Hmm, I haven't tried that. I will try to give it a go and see what happens next time I'm in the car.
