Re: Allroad Air Suspension Compressor strip & repair
I have a problem I can't put a finger on.
Compressor rebuilt. Kicks in fine air fed to front.
Both front bags flat on bump stops. Even changed one bag but still same problem.
The rear right is also down and rear left is only one that holds up.
compressor kicks in, Light flashes then goes constant.
Sensor or airline leaks? I'm stumped. Anyone local to blackburn and I can sort beer tokens!
Rear seems equally raised but higher than level 1.
How long does compressor run for before light goes solid?
do front airbags feel firm (full of air) or empty
Runs for a good period. Maybe 120 seconds. The airbags are firm and fill with air when the car is on jacks and when it's Low they just sit on the stops.
Ok, did it lift before fitting the refurb kit?
Check compressor performance by blocking output hole with your finger, a good compressor will blow air past your finger. Check this, if poor compression check piston ring is fitted correct way
Best regards
Andy
The rear is lifted and the front air lines have air going in them.. I will check the compressor but before this it was not lifting also
Ok, both front airbags are definitely firm to feel?
With car on its wheels sitting low, start car light flashes, compressor runs and it should try for 120 seconds. Can you see any movement at the front?
Best regards
Andy
All that you said happens light flashes and compressor kicks in
Ok, check compressor pressure with finger,
Who did you buy compressor kit from?
Best regards
Andy
