I looked at Autodata belt book. It shows 2v and 4v marks for Lupo/Caddy/Polo If you need it I could try and scan it and upload or emailit
Printable View
Attachment 18363
would that be this one Paul
Yes mate, minus the oil! I think autodata is pointing more to the 2v mark???
It must be spark related in some way. Have you you tried turning it over in the dark, long shot I know but I'm really running out of ideas!
Took the inlet manifold off again and cleaned up everything, I will get some more plug leads and try tomorrow, and do a dark crank to see, compression tested once more as I'm loosing the will to live.lol all 4 over 13bar. Tested crank sensor again and that's flashing as I turn engine by hand. I have removed plugs one at a time and tested spark. Unless arcing in situ. After that it's the ecu but I may run to VW before that?? Anyway soldier on. Never had a car beat me yet apart from BMW where 3 injectors just went down, I found the error but couldn't believe it. BMW came to the same conclusion after 6 weeks..
Anyway thanks again and I'll keep you posted.
I like that, endeavour to persevere if all else fails matches are 20p!
Hold the matches...
All done and fixed Paul it was the Plug leads as you suggested, went to Halfords - they don't stock nor can get any.. So I went to scrap yard and got four from there.
Anyway all done so big thanks to all.
Wouldn't have believed it I took the plugs out and placed in the leads last night and all fired OK..
Just goes to show - I feel ashamed to say I was an electrician for years and have also done Auto electrics..
Everyday is a school day
I have also uploaded testing Sensors to YOUTUBE sorry it's not great..
CRANK & CAM SENSOR TESTING - the easy way - YouTube
and if anyone needs a copy of the full and complete Valve replacement guide I’ve done please let me know.
MOT time next - BIG THANKS!
Just grab 6 cold ones and 10 fags
