Re: Interior lights after turning off ignition.
Quote:
Originally Posted by
johnsimcox
On my 2015 car they do not turn on when I press the stop button. However pressing the button again (with foot off the clutch) turns the lights on and also switches off the radio, retracts the mmi display, turns off the exterior lights and unlocks the doors.
Perfect! That's exactly what I needed. Press the off button again and everything lights up. Thank you 😀
johnsimcox
Thanks, it works this way.
Still would be better if this would be done without the double click :)
On my 2012 A6 Avant, pressing the stop/start button to turn the engine off (foot on the brake pedal or not) the engine stops but hte MMI remains active. With your foot off the pedals, pressing the button again shuts down everything and turns on the interior lights in the same way that opening the drivers door does.
My fathers 2013 A6 Avant does the same too.
If these were "normal" cars with "normal" keys, the process would be when removing the key the lights come on. Pressing the button the second time/opening the door, is telling the car you've finished and will be getting out.
tomas_v
Am i missing something please? I have a 2017 Tiquan R-Line Auto. When i pulled into the drive last night, i pressed the On/Off button and pulled the handbrake button, took my foot off the brake and pressed the On/Off button again but the radio stayed on and the lights stayed off. Any advise would be gratefully received.
hanks1878
Think the Tiquan section of this forum Tiguan would be a better place to ask this question as this will be a vehicle type specific function. This is the Audi A6 C7 forum
Thank you. I have now posted on the Tiquan section of the forum.
