Yes that is just the s-line bumper, for the UK the bumper options appear to be RS6, S6, s-line or SE.
Printable View
Are the headlights from a.pre facelift the same as the face lifted model??
Also... could someone PM me a dwolaod link to etka please?
The Facelift Xenon's had the LED drl's fitted internal to the headlight so the wring is different.
I thought things were getting better.... sadly they aren't :-(
I can easily see why the S Line bits were stolen :-(
Anyone bought an upgrade kit which was from a Red Audi A6 ?? :-(
Most likely stolen to order.
Apologies for asking and being a pain......
Any Help with Part Numbers would be great.
I don't even know if the car had round or square fogs fitted. :-(
This is what I have....
Basically..... the Rad pack is there... the OS Intercooler is there.... but no connector pipe.
Attachment 30101Attachment 30102Attachment 30103Attachment 30104Attachment 30105
ok.. i've found ETKA.CC - it appears that
4F0 807 105 AD - is the bumper I need and the fogs should be the round type ones.
The Car Arrived this morning....
all parts were in the boot. but there IS some damage.
Needs a front bumper and NSF Foglight and surround.
Needs rear bumper paining (Underneath) and a new diffuser fitting.
Needs a NSF Headlight as the mountings have broken from the unit.
required Both Rads, the NS Intercooler and intercooler link tube.
also requires radiator mounting (front) panel.
so... my question is....
will this fit???
2006 AUDI A6 C6 (04-08) 2.0 TDI RAD RADIATOR PACK SLAM PANEL TWIN COLLIN FAN | eBay
You don't need a light, you can buy headlight repair mounting kits from Audi, cheaper than a headlight.
Not sure if the front panel is the same but, but the crash bar is different on the FL.
@B5NUT Cheers Pal.. I might take a Risk and buy the rad pack.. although... I will look on etka again and see if I can find the panel... the Rads look the same for the 2.0TDi range. And possibly the air con condenser. ...
Oh.. and thanks for the advice on the headlight repair kit... that will save a small fortune.
Thanks again.
Wayne.
